Can I use tie straps for romex on metal rafters?
M Mdaddyrabbit Well-known member Joined Jun 19, 2016 Messages 96 Location North Carolina Mar 19, 2019 #1 Can I use tie straps for romex on metal rafters?
A alfredeneuman Well-known member Joined Mar 3, 2011 Messages 4,596 Location Fullerton, CA Mar 19, 2019 #2 You should be fine strapping to the face of the rafters. To run NM through any holes in them require the use of grommets.
J Jim greengo Well-known member Joined Sep 3, 2018 Messages 7,415 Location Behind my house Mar 19, 2019 #3 Picture? Running through holes in studs/rafters with stud gaurds would probably be better depending on conditions.
OP M Mdaddyrabbit Well-known member Joined Jun 19, 2016 Messages 96 Location North Carolina Mar 19, 2019 #4 Not easy boring a hole through the 2" beams. 2 holes per beam. I been using a carbon tip hole saw. Wears me out after about 6 holes.
S sberry Banned Joined Jun 18, 2005 Messages 35,747 Location Brethren, Michigan Mar 19, 2019 #5 Holes in 2 inch beams,,, ?
C checkthisout Well-known member Joined Sep 5, 2008 Messages 5,232 Mar 19, 2019 #6 Mdaddyrabbit said: Can I use tie straps for romex on metal rafters? Click to expand... Are the tie straps UL listed for securing NM cable?
A alfredeneuman Well-known member Joined Mar 3, 2011 Messages 4,596 Location Fullerton, CA Mar 19, 2019 #7 Tie wraps are listed for securing a number of electrical cables and conduits (NM included).
