bolecailey
Where the subframe mounts to the unibody of my E46 M3, my car has developed the cracks that this generation of BMWs are notorious for. Rather than paying someone $1500 to weld up the cracks and weld in the reinforcement plates, I would rather buy a welder and have my dads friend that has been welding for a living his entire life do the welding. I would rather just borrow a tig as money is tight right now because I had to buy a new differential for (discovered the cracks when I did an inspection after pulling the differential). The problem is no one I know with a tig has anything remotely portable.
With all that being said, I have done some research but don't know enough about welding at all to know the difference between the models and what I need and will probably want when I learn what I am doing. What I plan on using it for after this job is mainly automotive type stuff. I have been scouring craigslist for a month and have not found anything small enough for a garage in 230v single phase power at a price less than a couple of hundred dollars less than I can get a new machine for. I have been looking at the diversion series 165 and 180 but keep seeing people recommending spending the extra money for a synchrowave 200. I open to all brands and would prefer to spend as little money as possible but I tend to be a buy once cry once kind of person. I will say that even after I learn to weld, I suspect I will only use the thing once or twice a year if that but I plan on building a track miata and I will likely come up with more uses for it in the future. I hate to ask these questions when a search and research often has the answers, the problem is I know so little about welding that I don't understand what makes one machine better than the other or even what I need to get the job done.
Also, if there is something for $400 or $500 dollars that would get the job done, I would probably rather just buy that than spend the money on something expensive only to want something better in the future. The steel is a 1/16'' and the reinforcement plates are about the same thickness. Here is a link to some a thread with some pictures of exactly what will be done. Link!
Thanks,
Cole
Thanks,
Cole
