Time For a Garage update
Roadking96
Holly Springs, NC
Been thinking about doing some updates to the Geerage, and found this place. How great is that?
So things I'm gonna be looking at:
  • [*]Need a 220 outlet for Compressor
    [*]Need to add a couple more 110 drops
    [*]Need to plumb for Compressor with PVC or Copper
    [*]Need to raise opener from standard to max ceiling height
    [*]Need to probably upgrade to liftmaster
    [*]Need to figure out which is best/quality/for money 4 post lift
And that's just for starters. I'm sure they'll be more suggestions on how to spend my money.....:thumbup:
How am I doing so far for starters.....
Lookin forward to your input(s), expertise and reading / searching out answers.
RK
rsanter
visalia ca
you need to look at why you think you need more 110 outlets and what you need them for.
if you have a spot with a stationary tool or a work bench then you need an outlet there.
if you are thinking about places you can plug an extension cord into, then you need to add a couple of the drop down type plug reels
when you add the air lines, you need to think about if there is a place you will want to put an air outlet on the outside of the house?
when you install the compressor you will want to install a ball valve and drain line that will make it easy to drain the tank and run the drainline through the wall and outside so you dont have a mess to deal with inside
bob
