When you mount a low profile or run flat tire, it helps to hold the tire down far enough where it has enough room to stretch on. The top of the wheel has a lip that the tire uses to stay mounted onto the wheel, and if you don't push the tire down far enough you can damage the tire. These little clamps eliminate the need(most of the time) of having another person use a bar to help you.
