Tire changer
rosadoauto
I want I tire machine for my home garage but I have a cheap compersor 40 gallon tank 160 psi 8 cfm will it work
Sent from my SPH-L720 using Tapatalk
epmills
Missouri
What are the requirements for the tire machine? The type you buy can vary greatly. The one I use at work only uses air for the wheel clamp down and airing up the tire, everything else is driven by an electric hydraulic pump. You could probably run it with a portable 12V cigar lighter compressor...
rslaback
Westcentral Wisconsin
The one I have at my school would. They use a surprisingly little amount of air. The rim clamp is air cylinders and the bead breaker is an air cylinder but neither require a lot of air instantly. The turntable is electric. The bead blast seating function does use a lot of air but the machine has a built in reservoir behind the main post that stores air for that.
