Tire lift For The Geriatric....
Renegade1LI
long island ny
I can still lift a wheel assembly but using a pallet jack looks like it will make it much easier. Will have to try when I mount these, definitely will make equipment wheels much easier.
Skellyii
KC Area
You are lucky if you have studs...
Not so much if you have wheel bolts...
Trying to lift the wheel and get the bolt started is a whole other issue...
Great idea Crow Horse
HF and others sell removable studs for tire changes. I use mine all the time, makes thing much easier.
HF lift pins
CraigStu
Blacksburg, Va
One could also install lugs permanently and no longer have to put up w/ the BS the manufacturer stuck you with.
IMXCITD
Virginia
I'm getting up there in years and after having 3 knee surgeries, I'm at a point where I must work smarter and not harder, or else I pay a premium price. After having a great deal of difficulty lifting the tires of my Tacoma onto the hubs and straining my back, I had to figure out an easier way. I decided on a car dolly from Harbor Freight might be the ticket. It will lift my tires 3 1/4" - 3 1/2" which should do the trick. The only modification I made was to add small pieces of Kydex at the ends of the rollers to prevent a metal on metal situation...
great idea on working smarter. Your post reminded me of a small Harbor Freight car I have that also has a lift.
OX1
Jackson, NJ
Yikes is right. I think I paid 800 bones for mine. Still better than back issues though. Those 35’s are heavy and I’m old. 🤣
I looked at things like that. Made my own with cheap lift table that goes up 50 inches and a linear bearing/rod set.
Total less than $300
I wanted it to be able to extend over a 4 post lift.
Holds up even a 35 without flopping over forwards, which I was surprised about.
Can also come in at an angle, with rods able to move in and out.
Some of the areas around my 4 post are kinda tight.
aka Larry
Eastern, NC
Mine works well for 99% of my needs, but I'd have to say yours would be better to raise the spare tire into place when I do the 5-tire rotation on my Jeep. About gave myself a hernia with that one!
  • Like
Reactions: OX1
