tire side wall cutter?
Handyfarmer
in the high plains of Colorado
been thinking about making a tire sidewall cutter,
One for the possibility of reinforcing a roadway that keeps washing out, and my second Idea was tire retaining wall, and after watching a few "earth house" videos on ramming the tires, it looked like removing the top side wall would be beneficial
thus the idea of the machine,
came across this idea for roads, (I have some problem areas) called mechanical concrete.
https://www.youtube.com/watch?time_continue=3&v=VrzOh8dfw0w
web site
http://www.mechanicalconcrete.com/mechanical-concrete®-advances-road-building-in-the-us-and-abroad/
I came across this video and think I could improve on it, Manual Tire Sidewall cutter
My idea is to improve the cutter, is to hold the tire on the bottom of the tire, bead, using channel lock pliers, on the top left show the concept,
(the commercial cutters have a back under the cutter) so my thought was to make a set of rollers that would fit in side of the tire and roll around supporting the area where the cutter is, and using the same kind of manual walk around lever on the cutter, the cutter arm, would have a slot for easy removal to set the tire on and off,
(I guess if one wanted to remove the second sidewall, one would have to extend the base out to catch the area where the first side wall was cut off),
my second Idea was tire retaining wall, and after watching a few "earth house" videos on ramming the tires, it looked like removing the top side wall would be beneficial on the retaining wall,
jsaw
Geneva, N.Y.
How many tires do you need to cut?
At work, we use a utility knife to cut sidewalls out of tires. Have also seen it done wi t h a reciprocating saw.
kctyphoon
Jersey/Staten Island
I’m willing to bet an aggressive blade with a sawzall used at low speed would work wonders. I’d imagine the high speed cutting with any type of saw blade would result in massive binding from the heat being generated.
finn
The UP, God's country
I found that a normal circular saw quickly slices through the sidewall of your trailer’’s spare tire when you are using the spare to keep your work off the trailer deck.
Billythekid1
We would take a old sawzall blade and grind the teeth off makeing a unserrated blade like a pocket knife it would cut the steel core better for some reason
