I am liking the idea of a raised heal, I did some sketching and I think it could work pretty good. When I drop back from 10/12 pitch down to 8/12, I fall below 25' and things look well proportioned. Some CAD sketching below.
[/URL][/IMG]![]()
Here is a quick video of my garage with attic trusses. It was a quick video, and it's rough, but you get the idea.
The roof is a standard gable, 8/12 pitch with standard attic trusses. Garage is a 30x50.
I keep reading about extra cost for attic trusses? Is it a because they can charge whatever sort of thing?
The truss cost would be expected to cost more, just by way of more material and labor to build attic trusses vs conventional. Then the labor to frame and set trusses, additional decking materials and labor, handling girder trusses, framing stairs etc etc, its a snowball effect.
Hello,
I am putting up a 24 wide by 36 garage and am debating on attic trusses. I’m doing a 12” footer and 4” slab
I don’t really want the 12/12 pitch though. Totally new and a rookie at this and looking for advice.
In Alaska
Thanks all
With a 24 foot wide building you'd need at least a 10/12; You could cheat a little on the interior height. The 2nd floor of my house has 7-1/2 foot ceilings. It's not bad. the dimensions on my house are a bit irregular, but not far off 24 feet and 10/12. You generate a lot of room.
Still in the dream phase of planning my detached garage build. I am estimating a size of no more than 1200 sq ft. (30 x 40). I am going back and forth about attic trusses. The biggest concerns against are cost and some loss of floor space with interior steps (I am in MN).
Biggest mistake I made when building by detached garage was not using attic trussesI Kick myself every day over it. The slight additional cost and the very small amount of space lost to the stairs would have been well worth it over the years.
I did the analysis, I couldn’t build a shed that size for the additional cost of attic trusses, the few extra roof sheathing, shingles, and 3/4 OSB for the floor. I have 800 sq ft upstairs! Bottom is 36’ x 50’, 2nd floor ‘attic’ is 16’ x 50’.
Sweet shop!
I Second was my code dept said I would have to do full footers and walls if I had them or a second floor of any type.
I chose to go with gambrel attic trusses and super happy I did. It was for sure more money up front but the square footage I gained is awesome. I just waited a little longer and saved up the extra money. No regrets at all. As for the stairs waiting up floor space I did also decide to make garage a few feet deeper (price option for that wasn’t too bad) and built the bathroom and utility/compressor rooms underneath.
