TimBobUSA
To Reframe, Or Not To Reframe Wall w/OH Doors
Hey folks,
I could use some more of your advice on my never ending shop (garage) renovations. I recently removed the sheetrock, insulation, and vinyl siding from the south wall, which has two 8x7 overhead garage doors, and discovered framing like I've never seen before. The sill plate is 2x6, the lower wall framing is 2x6 and goes to just above the doors and is not 16 or 24 OC, and upper framing is 2x4 and goes from top of the doors to bottom of the truss and is mostly 16 OC. I believe it's been this way since the building was constructed 20 - 30 years ago. It's survived multiple hurricanes and being left abandoned for the last 10 years.
Should I leave it as is or re-frame? If you think I should reframe it, can you direct me to a detailed framing diagram? Everything I'm seeing online states that I need to follow the portal framing method for anything over 6 feet wide. http://cdnassets.hw.net/89/14/4301ab0b446fbbb4f853732b6d42/0817-jlc-apa-portal-03.jpg
This is 26x26 and is out in the country, in the Piedmont of NC.
I'd prefer to reframe it using 2x4's on top of the 2x6 sill; matches other walls.
I like the look and functionality of having two doors.
Purchasing new overhead garage doors isn't an option right now.
Hey folks,
