There is coupon and sometime sale for $9.99 on both 3/8 and 1/2.
The 1/4" also goes for $9.99 just not nearly as often.
Interesting read, especially the part where they don't set the torque wrench back to zero.
Torquing - Testing Torque Wrenches
http://www.fourwheeler.com/techarticles/129_1307_torquing_testing_torque_wrenches/
thats funny, same article as carcraft., slightly reworded and 4 months later
i would have to say that with the torque stick, you will still get the full reading on the torque wrench. IE, using a 70ftlb stick on a TW set to 100ftlbs, you would get 100ftlbs.
the best way i can explain it to people when they try to claim deep sockets or extensions change the applied torque, has always been handing them something long and flexible, like a ruler, yardstick, 1x4, etc... something that obviously twists, and have the twist it between their two hands. then ask them to explain to me how the stationary hand could be "receiving" less torque than the hand that is doing the twisting....![]()
if the wrench clicks, or shows that 100ftlbs is applied, it is completely transferred, regardless of twisting or length from TW to fastener. changing angle will affect though, such as a u-joint, or wobble.
You'll find that they're both owned by the same media company.
Extensions affect applied torque on impact wrenches, which is often misconstrued as extensions affect torque from a torque wrench. The sudden impact that an impact wrench creates, and the moment of inertia changes the applied torque (if I can remember my physics at all...). Steady even pressure takes all of that out of the equation, and keeping the extensions at exactly 90 degrees is the problem![]()
i believe that has less to do with the actual extension being twisted and more to do with losing energy through more contact surfaces being turned, if you take a socket and extension and put it on an impact wrench and just twist the socket back and forth, youll find a little play between, and as the gun impacts, the whole thing will go back and forth on the drive, extension female, male, and socket ends, you will end up with better torque transfer if you hold the extension steady and twist in the direction you are going with your hand for a more solid impact without lost energy through extra movement being made between impacts.
Bravo!! You nailed it.wrong. its all about the extension twisting. there should be little to no play in the impact/extension/socket assembly. all extensions twist, period. that springiness is how torque sticks limit torque. a regular extension is no different, other than it not being "calibrated" or designed and tested to fall within a certain range of loss.
so how do i get more torque (far more) when just holding a 3/4" entension steady and up against the socket and bolt, as opposed to letting it impact on it's own, jolting back and forth?
you are right, there should be little to no play, but there is some, and the more pieces you adapt the more you get.
