Toilet flange position?
honza.vosalik
Missouri
I need some advise..
I just had a plumber replace a toilet flenge. He said it needs to settle and will be back tomorrow.
Now looking at the flange I'm confused, I'm not plumber, but shouldn't it be turned 45° for the screws to go correctly?
FredWanaker
NorCal
Looks like he will be using the slots at 9:00 and 3:00. From what I have read, there is less chance of cracking that way as the long slots are more prone to failure. I am not a plumber, just reading online many sites say that.
Steve W.
Southwest oHIo
I just had a flange replaced and asked the plumber the same thing. His reply was that the short slots are stronger. As long as the flange is mounted properly, you shouldn't need to "adjust" anything. Yours appears to be done correctly.
yeldogt
That's how I do it ...
Even straight in they give a bit of wiggle room .... You want them square to the wall as it looks he did.
You only need the others when the flange is not installed correctly.
nadogail
Coronado, CA
It seems that your plumber knows what he is doing. If he doesn’t get it I right he should be able to fix it on his nickel
FMB4
Yep, that's how I did such as a 50 unit apartment complex 'super' (ha-ha) back in the day.
Renegade1LI
long island ny
I really don’t like the plastic ones, the ss ones won’t crack or rust, just installed this one in my sons house.
