Tool for Honda Electrical Terminals
cjarvis
What tool(s) do I need to dis/reassemble the electrical terminals on Hondas?
engineer2
Chicago burbs
I just got the 60-pc universal kit from Amazon. It has some duplicates, but some of the terminal stabbers tend to be fragile.
LXCam
Steelman tools makes a generic kit that isn’t bad. It’s not as precise as a dedicated pick set but I’ve always s made it work.
Showkey
"MEMBER EMERITUS"
Wausau WI
90% is knowing where and what to push or pull to get the release.
Universal kit or tools would be the best choice.
If you know the release trick…… a stick pin, sharpened and bent paper clip will work.
Terminal release and lock picking have a lot in common.
Reassemble no tools are required for most. Just direction and position.
Replacing a connector terminal ……..getting the exact terminal can be challenge as there dozens of choices in configuration, size, shapes.
These are old tools and pictures:
79565549-EA54-4847-AD4F-07DD9ECD9EED.jpegC5AA96F7-C2DC-4460-AE1E-C82833ACDECE.jpegF44847C1-3CF3-4EEB-BA44-86E60359318D.jpeg
midorix
1. Micro flathead screwdriver
2. Remembering which side has the clip
3. Patience
