Tool for new Outbuilding foundation dig
eclipse860
I just had a 40x36 post building erected. Concrete is not poured yet. I am stubbing in Conduit and other utilities. I would like to dig around the inside of the perimeter to lay 2-3" of foam board for insulation.
The base layer is about 8-12 inches of VERY dense, rocky material. They had compacted it down with a large machine in prep for the concrete. I just dug a hole by hand to stub in conduit for electric. It was back breaking work with a pickaxe and misc. shovels. It took me about an hour to dig a 1 foot wide, 2 foot deep hole from inside to outside. I cannot image digging 18" down around the entire perimeter so I can slot in the foam board.
Does anyone have tools suggestion or methods that might make this easier? I feel that I may need to abandon the idea :-(
jdl25
Is 3" of foam below the dirt worth all of that? I'd spend time and money elsewhere. But it is your building and you should do it however makes you the happiest.
billconner
Thousand Islands NYS
I think Hansen Buildings recommends a ditch witch trencher or similar, but when just posts are set, no walls.
If you're in a cold climate and heating building it makes a lot of sense to me.
GeoBruin
That's a good idea.
billconner
But not if walls are up based on what I read. Hit a big rock or pipe or something and you might tear a hole in sideling. No personal experience in this one.
mike93lx
Richmond, VA
With the big ride on, tracked units, I have found they don't jump around. They get stuck and shudder, but they are quite heavy
RPH
Michigan Thumb
I have an older articulated Vermeer trencher unit. Weighs in at 9000#’s. If you hits something big enough it will jump and buck around. One time it pulled an old stump from two foot down. That was a ride! But it’s one way to trench it.
I wouldn't want to use my Bosch demo hammer to dig more than about 5' of trench. If you use a trencher, pay attention to the direction of the exhaust pipe. Buddy stained his stucco with a dark stripe.
