Penetrant - PB Blaster. Lubricant - JD Super Lube
Super Lube Multipurpose Synthetic Lubricant (TY25733)Super Lube is a patented, multi-purpose synthetic lubricant with Teflon® that out-performs petroleum-based lubricants. The Teflon particles in Super Lube fill surface irregularities by compacting like snowflakes in a snowball to form a smooth lubricated surface. Machinery and equipment are protected from wear and corrosion. Maintenance and service requirements are reduced.
Features and benefits
· Waterproof and not washed away by acids or alkalis
· More product at a competitive retail price
· Lasts four times longer than petroleum-based lubricants
· Cleans and penetrates – then evaporates, leaving a non-toxic, long-lasting film of lubricant
· Does not melt, wash out, dry out, separate, or attract dust; resists temperatures up to 750 degrees F (399 degrees)
· Does not harm the soil, turf, hay, or animals with incidental contact
· Contains no CFLs or chlorinated solvents to deplete ozone
· Synthetic with Syncolon PTFE – bonds to surface to add lubricity to moving parts
ApplicationsUse on machinery and equipment including:
· Bearings
· Cables
· Pumps
· Locks
· Gears
· Conveyors
· Valves
· Linkages
· Chains
· Pulleys
· Hinges
· Bushings
Safe on rubber, wood, and metal.
