Tool name?
WTXTundra
Odessa
So I found this tool in a metal rtu cabinet. I’m guessing it’s a punch or drill bit starter? Anyone familiar?
I have similar shaped items as scribes, or scribers, for scratching a line in wood, or Dykem (sharpie) on metal. I have several, a Lufkin 87a is the first one I found. The tip unscrews and reverses in the body
cgrutt
Tip wouldn't happen to be spring loaded would it? If you push hard and it clicks and leaves a dimple it could be automatic center punch. I have an old Snap-on (I think) that looks similar but with a red body.
W
WTXTundra
Odessa
You guys are great. It’s definitely a scribe. No spring inside to make it a punch tool. What’s weird is that the scribe doesn’t fit inside the handle. I figured it would be able to screw it back in to the handle while not in use.
Either way, it’s works great.
66HertzClone
Long Valley, NJ
It has been my understanding that the tool on the left is a scribe, having a hardened point instead of the point on the pick has.
Beerhippie
Far NE Oregon
"Scratch awl" might be a better term for unhardened scriby things. For softer materials like wood, plastic, etc. I tend to use mine as a pick and the carbide scribe for marking. If I need fine marks on wood or plastic, I use a knife.
Beerhippie
Far NE Oregon
Moody magnetic scribe
That's funny--those are nearly identical to the Ullman set, except for the anodizing and the individual handles. The one second from right is what I use 90% of the time for removing o-rings.
I hate the magnets. They only seem to be good for making sure you never grab one tool at a time from the drawer.
