Any way to tell the age of the set?
Hello I am new to this site, but definitely not to toolmaking. But I have question for you and I hope you can help. I’m curious about dating my Gerstner toolbox… wait, that didn’t come out right! LOLYou're touching on one of the three things I do when purchasing used tooling, age and history of the tool. First off, metal does not reveal much info for date of origin but does show the history of duty, wood wears it's age and pedigree with pride. You have to look for the clues in less obvious places.
Begin by examining the outer surface of the top/lid. Does it have a faded logo on it? Makers of industrial tooling used to have their logo/brand name on the outside. Some do/did on the inside as well. Product pride meant a whole lot more years ago than it does now. Makers wanted you to remember their product by a glance when you pulled it out and put it away. Quality tooling is like that. Now it almost seems as if they don't want you to remember how poorly something performed in hopes you'll forget the name and buy another (but I digress......) If there's no logo remaining then you next look at the fitment of what's in the container. Do the products appear to properly fit the cut-outs well or has the case been re-purposed from a different maker?
Next, examine the type of wood used for the case itself. Does it look like Pine, Poplar, Boxwood, or some nameless variety of white-wood? Decades ago (showing my age here...) companies that made a top quality product often charge top dollar for it too. That price demanded a good looking, durable case appropriate for the contents. Industrial hand tools often had cases made from maple. Measuring instruments had cases from mahogany (Brown & Sharpe for example). Very fine instrument cases were often made of cherry (for a different reason), often had a "French Fitted" case with a velveteen material to protect the instrument (Lufkin dial indicators for example) that might be covered in a leatherette type of material (Gerstner tool chests, Lufkin and Federal indicators). Quality of packaging/storing was important and you would know at a glance there was something special inside. Distinctive colors/materials were also used to associate a brand, still are for lots of things.
The inside of a "fitted" case can also be a clue to age. Open cell foam is used to keep things from rolling around in the case and protect surfaces from banging into each other. Open cell foam started replacing the velveteen material because it was cheaper, a bean counter type decision. It works ok but it does deteriorate after a few decades into crumbly particles. I have a couple of originals for micrometers (inside, depth, etc.) that were a crumbly mess after 25 years. If it still looks ok and is solid then it's been made in this century.
As injection/blow molding became cheaper many makers started going with the cheaper plastic cases, that started in the mid 1970's. The imported tooling still used wood for a case as molded cases were more expensive for a product they weren't sure if it was going to be around for very long, still do for a lot of the cheap Chinese stuff. You can tell a Chinese made wooden case almost blindfolded by sharp corners, inexpensive type of wood, cheap lacquer finish, and cheaply made hinges. Before it sounds like I'm knocking imported tooling let me say that I own tooling/instruments from all over the world. I still have a Polish made micrometer I bought in 1979 that I trust. I also have a newer made threading die made in Wisconsin that was **** from day one.
As for your set (finally) I haven't seen a tap/die set in an original wooden box for decades. IF original, it might have been made in the late 1960's or 70's. It could also be a home/shop made box to hold/protect the contents instead of rolling around loose in the toolbox. I've re-purposed several cases from different makers and also made several cases from wood for my own tooling that came with no case or a crappy plastic one. Wooden cases get the shyte beat out of them, particularly in a rough shop environment. If the user(s) paid for it or were conscientious workers then it might be OEM. I try to be careful with mine as it's part of the history of the tool and maybe the next owner will be curious enough to want to know the history as well. Examine the case, clean it up with gentle cleaning products (no sanding) and a light coat of BLO (beeswax optional) rubbed in well will make it look good. A light coating of oil on the steel components will help prevent further rusting. Post up your findings, I'm curious about it too.
My apologies if I've bored anyone with TMI, I'll go sit down in the back row now.
I apologize, I can’t believe I didn’t even ask you the question. What is the rule on dating the box by this method. Because I’m pretty sure that this box is from the WWII days? Thanks againYou're touching on one of the three things I do when purchasing used tooling, age and history of the tool. First off, metal does not reveal much info for date of origin but does show the history of duty, wood wears it's age and pedigree with pride. You have to look for the clues in less obvious places.
Also, on top of what four.cycle said, look for the guide to wooden toolboxesI apologize, I can’t believe I didn’t even ask you the question. What is the rule on dating the box by this method. Because I’m pretty sure that this box is from the WWII days? Thanks again
Frank
-Well hey there Frank. Dating your Gerstner? We don't kink shame here.....very much. Welcome from the foothills of Appalachia, pull up a chair and join the conversations.I’m curious about dating my Gerstner toolbox… wait, that didn’t come out right! LOL
-I'll apologize for not knowing a lot about Gerstner, they were almost always out of my budget range and the bulk of my extra(?) cash went to measuring instruments instead of the really nice boxes from Gerstner. Once I did come across a deal on the large machinist boxes, top, middle, and roll around bottom, for $700 new and I decided to pass. I changed jobs quite a lot back then and didn't think the wood boxes would hold up to frequent moving. Wood chests were really supposed to arrive at your job and only leave when you retired.What is the rule on dating the box by this method. Because I’m pretty sure that this box is from the WWII days? Thanks again
I feel right at home already! I’m not going anywhere for a while (I hope not anyway)-Well hey there Frank. Dating your Gerstner? We don't kink shame here.....very much. Welcome from the foothills of Appalachia, pull up a chair and join the conversations.
-Me too, that almost feels like an AA meeting where I stand up and say "I'm a recovering toolmaker"Thanks for all your help. I’ve been a toolmaker
-We're about the same vintage and have likely chewed on some of the same grit. As a long time metal hacker you're probably aware of the multitude of differences in the boxes due to being able to order different woods and IIRC one could even pay a little extra for limited availability in more expensive grades of wood as listed in older catalogs. I've seen examples of tiger/flame/birds-eye maple, highly figured oak, walnut, and cherry that were distinctly different than the more common plain vanilla examples. Determining the date by font may not account for early prototype stamps or change-over but it should be close. I hadn't considered the leatherette explanation, thank you for that.for over 40 years
