Toolbox Base Question
clfan4life
So here is NoNN37's toolbox. The weight of the box sits on the frame. I am buying a 722 this week and was thinking about building a frame for the box.
Now this box will not be stationary. It will be rolling from hangar to hangar. While the hangar floor is smooth, the ramp is asphalt and a little bumpy. Is this worth doing to have less stress on the frame? Will the 722 casters hold up to this kind of movement?
Credit to NoNN37's toolbox picture.
jeffk14
GA
I used to work in that same environment years ago. Eventually, the casters WILL wear out on any toolbox. Especially if you're rolling a heavily loaded box across long distances on a rough ramp, day after day.
Just about everybody ends up building a frame and using industrial casters, usually repurposed from damaged aircraft maintenance stands.
Also keep a watch out for cracks around cabinet corners, usually starting at drawer edges and running out at a 45 degree angle towards the edges of the cabinet.
I've seen it happen on Mac, Matco and Snap On boxes, although the Craftsman and other cheaper boxes usually give it up a lot quicker.
