Toolbox Painting Technique
jbmorrey
I am painting a vintage Craftsman toolbox and am having trouble finding a suitable color. My challenge is that I need a flat color that has a little texture to it like the old Craftsman and Kennedy toolboxes have, does anyone have an idea as to how to make a flat paint get a little texture. i am limited to spray cans as I do not have a spray gun. i am thinking of some kind of technique that you could apply after the flat spray pint is put on.... any tips or ideas are appreciated.
James M
kmoon
Modesto ca
Home Depot sales a truck bed liner spray flat black with a light texture. Take a look at this
PRODUCT DESCRIPTION
The Rust-Oleum 15-oz. Truck Bed Coating has a textured non-skid finish and resists abrasion for durability. The coating dries to a matte black finish in as little as 20 minutes. The oil-based formula cleans with mineral spirits. The coating resists rust to help prolong the life of your truck bed.
Oil-based formula
Adds a protective coating to a truck bed
Dries in as little as 20 minutes
Matte black finish
Resists rust
Textured non-skid finish
Resists abrasion for durability
Click here to see Home Depot's spray paint buying guide
Actual paint colors may vary from on-screen and printer representations
MFG Brand Name : Rust-Oleum Automotive
MFG Model # : 248914
MFG Part # : 248914
J
jbmorrey
i think that's a little too much texture, what would be ideal is if i could find that hammers look, that has a little texture, but that are ALL glossy, don't care for a glossy vintage toolbox!! I'll have to see if they make that bed liner spray in a medium-dark grey, that's the color I'm going for.
Quiksilver
Loveland, OH
I've never used them, but do the "hammered" finish paints actually leave a texture on the surface, or just the illusion of texture? If they actually leave a texture, you could use one of them as a sort of primer, and then paint over it with the flat color that you want the final finish to be.
J
jbmorrey
Well, i think the hammered has somewhat of a texture, but not much, i think what I may tery and please let me know if you think this might work, spray on the hammered and when dry, take a 000 type of steel wool and lightly wipe it down, maybe that will take the shine away, either that or do they make a clear coat in flat?
James M
clarkjg33
Have you thought about an industrial paint and mixing in Homax's mix in texture and try rolling it with a foam roller?
cnc-me
MI
I used some stuff called Hammerite on a homemade tapping jig.
Went on real nice and dried fast, and still looks good years later.
NUTTSGT
Northern Central Ohio
I used some PLASTIKOTE bedliner spray can stuff. It only hada slight texture. The more you spray, the rougher it would get. I put a couple coats inside the tub my my granddaughter's wagon when I painted it, but I never painted over it.
From a distance.
EDIT: I used plastikote spray bedliner not Herculiner as I had earlier posted.
ConnerSmith
Gilbert, Arizona
You could just spray your bedliner down and then put your color of preference over it on top.
ckadams00
Seattle, WA
For the money and the ease of it it is hard to beat the hammered stuff. Colors are decent, looks good and holds up well.
