lilscorpion
Ok now that I've read your reply, you set your shelves or spreaders at the location with dominos to hold the location square and then pocket screwed into place. But no glue with the dominos? If so that's interesting.
Close. If I have access, I prefer to screw them together like in the pic below.
I prefer this method to pocket holes because they’re easier, faster, and stronger. In situations where I do t have access to do so, like in the first cabinet where I have spreaders on both sides of the board, I do one side while I have access and then use pocket holes on the other. Just so happens the first pic I showed only showed the side with the pocket holes.
You are correct on the dry assembly part. I do not use glue on cabinets. I will use glue for very specific things but avoid it if possible. Glue is final, my organization strategies are, as I've learned, temporary.
Thanks for the tips on epoxys, looking forward to seeing what I can do with them.
