Tools for extracting screws
engineer2
Chicago burbs
Any tips on removing a large quantity of cement board screws from a plywood subfloor? The square drives are filled in with thinset. Prying them up splinters the plywood.
Anybody know of a screw extractor that grips the perimeter of a screw head?
M_George
Eastern Pa.
I have the Vampliers, don't think they would work well for that. You need to be able to grab the screw head with them. I would use a hard sharp scribe and punch the mastic out of the screw slots first. Doesn't take but seconds each once you get the hang of it. Then a good clean screw bit on your drill should bring them right out.
grumpychevy
Indiana
You could always drill the head off, somewhat like drilling a pop rivet, then lift the plywood and cut off wheel what's left of the screws down to the floor joist.
thursday
Utah
Are the screws sticking proud of the subfloor? If so a couple options come to mind.
1.) No specialty tools required other than a cordless drill and it's keyless chuck. Tighten the chuck down around the screw head and then reverse the drill.
2.) A bolt extractor. Although a screw head doesn't have much of a head for the extractor to bite. Note these are different from screw extractors.
3.) purchase a few left handed drill bits.
E
engineer2
Chicago burbs
By the time I bust out the hardibacker, the screws will stick out a quarter inch. I might try the keyless chuck trick. If that doesn't do it, I may just put a metal cutting blade in my recip saw.
Iron-Iceberg
A-town
Hardened screws will eat your blade on the first one.
I would brake up the Hardie backer and then hit the screws with a cutoff blade on a 4" grinder.
unslow1
Illinois
That's exactly what I was thinking when I read the first post. It would take hours to try and remove them. Even then you would probably damage the floor anyway.
superautobacs
Vancouver, BC
I suggest using this type....like these Alden's:
6PTsocket
The Alden grabbit or any of the clones that look like the same tool. They are used with any drill with REVERSE. One end drills a very shallow dimple in the head of the screw. Phillips and square drives that center the bit are a piece of cake. The bit cuts CCW so as not to drive the screw deeper. Reverse the bit in the drill and the very tight spiral extractor grabs in that shallow dimple like you would not believe. The fact that you drill first overcomes the thinset clogged screw slot problem. I have pulled completely rusted in sheet metal screws with ease. They are also gauranteed for life. Mail in busted one and they send you a new one.
6PTsocket
The one weakness of the,akden is the extractor is better than the drill bit. The CCW drilledpilot hol
Danglerb
SoCal
Maybe a pick and/or some cheap bits and a small hammer to knock the thinset out of the heads enough to use a screwdriver bit to take them out. A couple taps with a hammer usually works with stuff like paint in the screw head.
Wamsutta
Amarillo, Texas
https://store.snapon.com/Special-Purpose-Pistol-Grip-Needle-Nose-Pliers-9-3-4--P636971.aspx
Snap-on 612AEP. It's hard to see in the picture, but there's two pipe grip jaws: one large one on the side, and then a smaller pipe grip jaw on the nose of the pliers that are perpendicular to the aforementioned side pipe grip. I use the grip on the nose when grabbing the heads of stripped out screws. These pliers WILL remove the screws, but if you have a hundred of them to do, you might want to go with something else. But for a small number of screws, they're ideal.
KnurledNut
n/a
I would probably tear the hardie up and just pound the screws in with a hammer.
Kinda depends on application.
Just my .02.
cherrybomb
Near Madison Wi.
I would also try the alden type tool after first hitting the screw with a punch and hammer.If you have one that doesn't respond,cut the hardibacker and use a vise grip.Another option is a left hand direction drill bit,just another tool in a tool junkies arsenal..
SRSemenza
This one sounds like the way to go to me.
Seth
6PTsocket
Don't knock it if you haven't tried it.
E
engineer2
Chicago burbs
Great Tips, thanks!
I thought about the reverse drive extractors, and now knowing they have a "pre-drill" feature, it may be worth a try.
A cut-off wheel would work too.
As said, if all that fails, just pound them in with a BFH.
I probably have 400 or so to deal with.
Wife hates the kitchen tile, so out it comes. It has a decorative texture that is impossible to keep clean. I also learned to never use lighter-colored grout. :headshake
unslow1
Illinois
The couple of times I have been it that situation I tore up the floor and used a hammer. I'm not spending hours trying to get screws and staples out if the material is cheap. I have done that on some nice hardwood floors but not cheap backer. I could have new floor in there before I would get half the screws out. Plywood is cheap.
Indiana
Vampire Tools dude they make pliers that grip the outside diameter and are made in Japan of good steel.
I have they're entire line up down to the scissors and demo blocks, they were sent to me via the marketing director himself to try out and show my family and provide feedback.
They are costly but makea few sizes from linesman to miniature pliers for elctronics.
Oh and really they are rebranded Engineer owned by Futabo manufacturing or something like that but decent quality, I've used everything and really like the t-handle extractor and the knife/wire sleeve stripper. GL
MikeF2316
Thornhill, ON
One other thing to try is using a cutoff wheel on edge to cut a slot for a flat blade screwdriver. This has the added benefit of loosening and maybe releasing the thinset inside the square drive holes.
