Tools from the old world
pozidriv
Belgium
Looking good :thumbup:
On the pictures they look a little on the short side, but that could be way off. How to these compare to other offset spanners lengthwise?
Tooling Around
These are my first ring spanners so I'm not sure how the size compares to others.
The 18mm-19mm spanner in the photo measures 275mm / 10 3/4 inches long if that's any help :)
ultgar
New Jersey
The 18mm-19mm spanner in the photo measures 175mm / 10 3/4 inches long if that's any help :)
That is short....the standard Facom 55a.18x19 is 290mm and the long version of their offset wrench (57L series) is around 400mm in length. A short (7") version is great for working in tight spots but not so good for leverage. SD
hautpot
California
New bits plus floor jack
franzdom
NC
Oh look at that nice shiny jack, brings back wonderful memories. Mine definitely doesn't look like that anymore but it's a great floor jack!
hautpot
California
Ya i was so close to buying the Snap-on FJ200, but i went with AC Hydraulic because I want parts available in the next two decades. MADE in Denmark����
superautobacs
Vancouver, BC
Wekador.....
I haven't seen that brand in quite a while. I think they aren't commonly found even in Germany....perhaps that's changed now. Amazon.de purchase?
Nice AC jack. I got to handle one at a local auto-supply store and they appear to be constructed very well...quite robust.
hautpot
California
Yeah I actually stumbled them because of a post Sir Monte typed a long time ago.
I tried out the Torx 40 today and so far no signs of inferior quality; Did not explode with brittleness nor did they deform the shape.
I got it through a wekador dealer on ebay.co.uk. All in all these are cheaper than all the other bits I paid for at an estimated $1USD per impact bit versus Makita Gold, Wera Impaktor, Wiha Maxxtor.
If you would like to test some out I would be happy to mail some your way (as I plan to reorder several hundred more bits);)
superautobacs
Vancouver, BC
Wow, thanks for the offer!
Several hundred :shocking: I think you're set for life.....unless you're running a business and supplying all the bits your workers require.
node105
Australia
picked this up last weekend, via fleabay.
C.C. arbor press.
Can't find any info on the brand.
Seems in good nick, the rust appearance is predominantly discolouration and red oxide.
Monte
Germany
On some CV joints there's very little clearance and if the crimp isn't flattened down it with clip the hub and break. Oetiker clamps for rubber airlines/coolant pipes and such are often crimped without being flattened, it's only the tension of the crimp that's important, but in some cases (VAG plastic CV boots) the flattening does make it a tighter crimp and less likely to loosen.
yeah i read about that issue in various car forums so i was debating about the Hazet 1847 or Hazet 1847-1...So in case i come across a VAG car i´ll look into the Hazet 1847-1 :)
(hopefully not since i just saw how a garage buddy changed the wheel bearing on an Audi A6...aluminium knuckle and steel bearing housing....very good idea...:sad:)
very nice stuff ! Beautiful jack ! :drool::pimpflash
Wekador.....
Everything is pretty much Wiha, Wera or import over here...
A small part of last weekends finds:
nice Seeger Ring pliers !
Carl Kneusel (Zeulenroda) slip roll.
Made in GDR (?). Probably made before 1955. The company is still around. With a new name though: www.raster-zeulenroda.de/en/
superautobacs
Vancouver, BC
Yes, that's my experience as well, working on BMWs, and that's why I thought the third jaw was a neccessity when doing ear type bands.
Things pretty much haven't changed then. Could it also be a regional thing, where there's no distribution network in northern Germany? Whatever the case may be, you have an abundance of other German tool brands to fill your workshop. :thumbup:
...and what does that thing do?
Moose-LandTran
The Brink of Insanity (England)
In some cases you can crimp it, gently tap it flat with a hammer, crimp again, etc and get the same result.
Those plastic CV boots are a pain. I always remove the entire shaft and do the job in a bench vice if it has a plastic boot.
Sometimes you can loosen the 4 bolts at the back of the hub and air hammer them to get the unit bearing out. They do seize with corrosion but i've replaced more hubs due to seized top pinch bolts than seized unit bearings.
Ford Transits (with steel hubs and steel unit bearings) are much worse for seizing up and becoming inseparable.
I bought my KD crimper years ago and it's the best one i've ever used. Never had a problem with it. 3rd jaw does the trick perfectly. Done many frustrating plastic CV boots with it and it crimps the clamp tight when other crimpers fail. They always crimp easy, but if it's not tight enough the damn boot pops off as soon as you turn the wheel. :mad:
losvre
UK
Dave455
Sussex, England
there's nothing made in England holding on for 40 years....
:rocker:
No, apart, of course, from my Record vice, which my Dad acquired at least 40 years back, and it was used then!
Now that I think about it, my Grandfathers Woden vice must have done double that!
In fact, the majority of my Dad's mechanics tools are probably over 40 years old now. British made Stanley and Steadfast screwdrivers; Elliott Lucas and Wilkinsons pliers; Whitehouse, Brades and Thorex hammers; Moore and Wright punches; Britool, Bedford and Gordon wrenches and socket wrenches - all 40 plus and still going strong!
My own Myford lathe is a 60's machine, my Centec mill a good decade older and even my Fobco drill makes the 40 year deadline! Pride of the fleet is my classic Drummond lathe currently being repainted - I've traced it to 1908 which makes it 116, and still working faultlessly!
Oh yes, most of the vehicles I work on are British, 40 plus, and still going!
Think I was even asked to work on some Daf once, but it was shite so the owner scrapped it!��
Superbec
Netherlands
You've never owned a Land Rover 110 then. Granted they are held together with duct tape and wire and have the worst ride ever. But they last [emoji39]
nope and never will, any of my cars/bikes must be either BMW,MB or Yamaha, now AMG has something to do with Ducati , that confuses me cause I don't like them at all.
You know I was kidding ?? :drool:
:lol:
HCNDM
Netherlands (tiny little country in western Europe
:lol:
Tbh I'll take a land cruiser over a rover anyday [emoji39][emoji6] they last forever too without the ductape.
I'm a Kawasaki or Harley man when it comes to bikes.
HCNDM
Think I was even asked to work on some Daf once, but it was shite so the owner scrapped it!í*@#$½í¸
DAF did make terrible cars. The trucks are nice though.
Can't really think of any cool cars ever made in holland other than donkervoort.
Spijker is made in uk these days if they still exist.
Dave455
Sussex, England
How about the Volvo 480? The coolest Volvo ever built!
Superbec
Netherlands
wow almost spilled my bier ...
here, some tools, the carb syncronizer is made in Germany, the inbus/torx sets don't know, they do work and come with 10 years warranty !!!!for 38 euros a pieces can't be beat :bounce:
