zeug
I believe that the Desoutter brothers made Douglas Bader's legs for him.
Just read the Wikipedia on Douglas Bader. Thanks for the prompt. Interesting man.
OK, one vote for each!
Thanks for the input guys. Would it be possible for each of you to measure the over all length and thickness of the head?
Also the dimensions of the case?
Thanks again,
zeug
I own wera and the quality is excelent,the moviment is very smooth and accurate in both direction
Mine is this and is Made in Czech Republic
https://www.amazon.it/gp/aw/d/B00BT...+bit+check&dpPl=1&dpID=41GGgFE9joL&ref=plSrch
The only thing i do not like is that the handle is very slippery if you have dirty oil hands
.Does anyone here know the COO on this facom 3/8" ratchet? I'm trying to find a simple set of 3/8" sockets + ratchet that's made in europe around €100~€150 but I have a hard time finding out which of the european brands still make their ratchets in europe, many of them seem to be from taiwan. I'm also looking at this set from Stahlwille which does seem to be german made, but again I'm not sure. Maybe you guys have recommendations other than the well known brands though, I'm open to suggestions.
Try searching, Hazet, Gedore, Stahlwille.
If I'm not mistaken they are made in Germany.
But find out if someone can confirm it.
The pear head ratchet is made in Taiwan.
The ratchet is made in Taiwan. A lot of places have this miss-listed, I know this because I brought it to the attention of KC Tool and they confirmed it through Wera and changed all but a few of the sets on their site. They also did it for Wiha.
https://www.kctoolco.com/wera-073230-bit-ratchet-1-4-drive/
On my box
<a data-flickr-embed="true" href="https://www.flickr.com/photos/137525160@N06/24186705097/in/dateposted/" title="s-l1600"><img src="https://farm5.staticflickr.com/4515/24186705097_af84915e93_b.jpg" width="654" height="756" alt="s-l1600"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Taiwan. I have the Sidchrome version, and they are also sold under USAG - all Stanley brands. Very nice set either way.
Here is one stahlwille 3/8 set. I got it two months ago from amazon.de. The price was then 130€, dont know how much is it now...
Ratchet has 30tooth and is strongly built, no quick release
I have older similar set with 12 point sockets and i have nothing to complain with it and that is why i got the other set(almost with the price of new sockets i got ratchet, extensions and case).
Cant say how durable the plastic case is. Metal one would be nicer but it seems that a lot of manufactures has gone to that direction...
Stahlwille is a bit cheaper than Hazet, but I think the quality is quite equal.
Personally i dont have experience with gedore ratchet and sockets...gedore might be cheapest compare to stahlwille and hazet.
Stahlwille and Hazet 100% made in germany, gedore used to be but i’m not sure how is it today...
As others have said, these are made in Taiwan. The older, and in my opinion better, style of 'Palm Control' ratchets still seem to be available, and are still made in Italy (by USAG I believe) where they always have been.
Here in the U.K. you seem to be able to get sets with either style of ratchet!
Yes, Stahlwille, Hazet, Gedore, Elora, I think Heyco, and a whole load of others make their ratchets in their own factories in their own countries. It's only when Stanley take over a firm that everything gets cheapened but the price! But do ensure that you get the proper tools, some firms offer a 'bottom end' range that is usually outsourced.
Stahlwille are just introducing new ratchets. They seem to look identical to the older models, but have slightly different part numbers and are all fine tooth. Have yet to see feedback on these but suspect they are going to be good.
Have a look at TBS Aachen for some good online prices on Stahlwille, Hazet and Gedore. British eBay seems to be best for Facom.
Plastic boxes are not good on any of of them with worst being the Stahlwille.
Sockets are kind of equal but Hazet and Gedore being stronger but thicker. Stahlwille very good and thinner for clearance in automotive work. For example both 1/4 and 3/8 Stahlwille have the same thickness for the same size.
Best knurling from Hazet. Tolerances Best Stahlwillle then Hazet and last the Gedore.
Ratchets I have both Stahlwille and Gedore. I like the ergonomics of Gedore better but Stahlwille is also very good. Stahlwille feels a bit tighter but Gedore has no Backdrag. Hazet is very strong but also coarse when new at least.
I also have Facom and the feel is best but the ergonomics of Gedore still better for me; quick release button, recessed lever for changing direction and handle shape?
Especially for the ratchets you need to buy in the shop for 2 reasons.
1. The feel on your hand and details
2. You can choose the one with the less backdrag. Most ratchets I have tested are a bit different.
Sent from my SM-A510F using Tapatalk
Any more pictures of the Tools? How do you like the saw compared to other brands by experience?Picture from cleaning up my portable table saw when done with it the other day. Thought some of you might like it.
Hmmm... in regards to your scissors inquiry, depends on application.
I prefer PAUL (DE) and KAI (JP) for handicrafts like cutting paper. OLFA (JP) always felt a tad flimsy in my hands...
Thanks!
My second gripe (and probably more important if you are considering purchasing one) is that the blade is somewhat of a pain to change because there is no access hole in the side of the housing under the surface to accommodate a tube spanner. The supplied pressed steel spanner, whilst stout enough is just at a convenient length to almost guarantee you will skin your knuckles on the teeth of the blade when you crack the retaining nut for the blade. I have a drawing done for a longer slightly different shape one to send to the laser cutting place I use next time I put a job in there to rectify the issue. Having now written this, I may also consider looking at whether or not I could punch a hole for a tube spanner too.
..really!)I'm doing an ensuite reno at the moment, I can take some pictures of the Metabo stuff I have in the wild as I use them
I have previously had DeWalt, Ryobi and Triton Table saws. Without writing war and peace on it, the Metabo is by far the most accurate, easiest to set up, easiest to adjust, and smoothest running (largely because it has a soft start), and most stable of the lot. I also really like that it can turn itself into a wheeled unit for mobility. I have two small quibbles with it, firstly I broke the door to the compartment where you can store spare blades for it off in fairly quick order when I started using it, but looking at the design it was always going to happen. I don't really use it anyway so Im not too fussed, I did put it back on and put some screws in it so it looked complete because thats just my natureMy second gripe (and probably more important if you are considering purchasing one) is that the blade is somewhat of a pain to change because there is no access hole in the side of the housing under the surface to accommodate a tube spanner. The supplied pressed steel spanner, whilst stout enough is just at a convenient length to almost guarantee you will skin your knuckles on the teeth of the blade when you crack the retaining nut for the blade. I have a drawing done for a longer slightly different shape one to send to the laser cutting place I use next time I put a job in there to rectify the issue. Having now written this, I may also consider looking at whether or not I could punch a hole for a tube spanner too.
So having written all that, I am in general somewhat of a Metabo fanboy, most of my power tools are Metabo and the lining boards of my garage have a Metabo green and red trim strip to cover the join up the wall (yes I took a German made Metabo tool to the paint shop for a colour match on the green..really!)
Hope that helps
I've had nothing but problems when it comes to Metabo. I'm currently attempting to purchase some replacement Carbon brushes for my 1100 Drill. Contacted them through their website several times, no reply. Found the part number, googled, amazon searched etc can't find it. Contacted them through their facebook page, nothing so far there either.
After this experience, and a previous experience, I'm about ready to just throw them all in the garbage and work with a company that will actually respond to an email or message and tell me where I can purchase parts.
I'm shocked at how bad their customer service is. Least Time Warner picks up my phone calls.
You'll need to find an authorised service centre to procure your parts. I have no issue obtaining parts (although sometimes there is a lead because they are not ex stock) from the authorised repair centre closest to my home. I live in Australia, you live in the US so your mileage may vary on that count.
Having said that, if its not working for you, move on to something that does.
Edit:
This may help you with a part number.
Part 42 on the exploded diagram, cost of AUD 38. (about USD 30 give or take at the moment)
http://www.toolspareparts.com.au/metabo-bde-1100-00806000-spare-parts.html
If you cant get them anywhere local, PM me.
Appreciate it. From what I looked up on the metabo parts diagram, I need 316035080 for the carbon brushes. Didn't have any luck on amazon.com, or Amazon.de. or eBay.
Metabo needs to step up and be able to respond to a customer who own owns I think about 8 or 9 of their tools now, and just needs 1 basic part. Not like I'm asking for free or warranty service.
The last time I tried to contact them to get service on a defective casting for the gear housing of a drill that I'd purchased brand new, I went through a very similar experience, paid 30 dollars to ship it off to them, to have it returned to me, and be told that it is a defect, they've notified the factory, but heres my tool back with no resolution as they saw it as being cosmetic only, and they then stopped responding to messages. So much for a premium tool company.
Thanks!
I don't know where you live but if you're in europe you can order them here: https://www.kruis.nl/onderdelen/metabo/bde-1100/v1
There are plenty in UK as well for good price I think.I'm in the USA
Woaa,18V SDS rotary hammer earning its keep..
I can post them to you but it would probably be after Christmas due to holiday season.
Have a look and let me know which is the part exactly you need.
https://www.mtmc.co.uk/Metabo-BDE-1100-/-00806390-/-GB-110V-Spare-Parts__p-102646.aspx
https://www.sparetoolparts.co.uk/metabo-bde-1100-carbon-brush-316035080-spare-part-type-806390.html
Argentina and SpainWhere are Bahco spanners made in?
I am trying to find a 27mm deep socket with deep nut insertion(picture)
Would like it to be at least 50mm...
Chrome or impact both would do.
I know hazet makes 4555 but the price is also very nice. Little cheaper would be nice for a job to do once in two years
Anyone know where should i search?
Woaa,
Thanks for the info about the table saw that would be useful once I need one☺.
Does the battery hammer has enough power to demolish few concrete slabs?
How long does the battery last in normal wall destruction.
Cheers![emoji106]
Very helpful,Im only stripping the screed coat out from under the tiles. Its plenty strong enough for that although the batteries arent really up for that amount of work, it eats them pretty quickly. To be honest, I was using it because it was handy (didn't have my corded one with me), I finished the job tonight with a much larger corded SDS hammer. Where it does excel is smaller holes in bricks for things like Ramset plugs. Also pretty handy for toothing out brick work because its lighter than a corded unit making it a bit more friendly for overhead stuff.
Hope that helps
