On paper, at least [emoji16]It seems that finally someone found out how to make Locking Pliers jaw!
Jaw HRC = 63 [emoji106]
<img border=0 src="http://matchbox.persiangig.com/LJ%20Locking%20Pliers.jpg">
Sent from my SM-A510F using Tapatalk
I bet you had to turn the old wallet inside out if you bought those Gedores in Norway. Do you have the regular 7 wrenches as well? What do you think of Gedore wrenches? I only have a couple of old Rotband hammers and an even older adjustable from Gedore..
I'm about to order a new set of wrenches as my current set is all a mix match of different things with a couple of sizes missing. Currently stuck on Hazet 600N..
Any of you guys more familiar with koken sockets and ratchets? I mainly use stahlwille and hazet but they dont offer so shallow sockets and ratchets than koken(as far as i know). How do they level up with hazet or stahlwille in long term use? I'm looking a 3/8 ratchet with extra shallow sockets and by quick looking around koken pop up first. Is there any german manufacturer that makes as shallow or close to koken? I prefer the satin finish and the koken all shiny chrome makes me wonder how slippery/hard the sockets will be taking of from the non qr ratchet...
Some new arrivals:
Hazet spurk plug socket
Stahlwille 3054 inhex sockets(used from ebay, very nice condition)
New goodies
<img src=http://drive.google.com/uc?export=view&id=0B6C2k8gbpjmpR0QyM3R2OWNsdUk>
Top stuff once more
Where the vessel T wrench and sockets are made in? I would like to also get these.
Thank you
It does say made in Japan on the package
Im sure it could be got via Rakuten. I would like that T handle also.
Just checked on ebay and yoy can get on in the UK from a Japanese seller for £17 something.
Got me a new drillin' rig, Bosch DP 500
The stand thing was made in Germany and of course my Bosch drill was made in Switzerland.
This thing is very well machined and honestly the first hole I just drilled with it is more square than any hole I ever drilled on the HF mini mill I sold a few months ago. It certainly gave my drill a bit of a workout doing an 8.5mm hole 25mm deep and so I can't really recommend pairing it with a crappy corded drill
I was looking for the following:
1. Well made
2. Easy to store (no permanent bench spec available)
3. Holes in aluminum up to 3/8" (10mm)
4. More use out of my Bosch corded drill I already own
And this thing works great for all of that. If I wasn't so sick of Chinese junk I would have bought a cheaper version or a benchtop drill press. I'm glad I went with this instead.
Padre socket set 989hs Made in Germany?
1. Well made
It is possible that the blue handle one is from Taiwan, for example I had ratchets like in your picture set 989 & like in 978 DS (black plastic ones). But tools were purchased in 2004 if I remember right and invoice stated that they came from Remscheid. Its almost 14 years so probably a lot changed in that time.
Yet another reason not to think again about this companyat least for me. If I have to buy Taiwan made tools I would stick to Sata, good quality and way down of Padre pricetag.
As a mechanic you always must to think about spending your money best you can ;-)
Opinel N.8 olive wood
Those Opinel knives are really good for the money.
The blades are superbly ground. I've encountered much more expensive knives with blades so badly ground you might as well have just taken a bar of steel and sanded an edge on it!
A couple of strokes on some sharpening rods and those Opinels come up shaving sharp!
I have a couple the same size in my tool chest and use them for everything from cable stripping to box opening!
A local shop has the Stainless blade versions, but I havn't seen the Olive wood yet! Looks nice!
Good knives, the Opinel's. I have one as my pocket knife. They hold their edge well, and mine's taken some fair abuse and is still going strong.
