Tools on wall
pfmg
Billerica, MA
Im looking to do a remodel of the working side of my garage, changing the cabinets and layout. Ill end up with more usable work bench, more usable storage and the ability to fit 2 jeeps end to end for winter storage. I'll end up with about 12sf of pegboard between the upper and lower cabinets. To make this work i need to get rid of one old craftsman rolling tool box, im thinking it will work if i put all the wrenches, screw drivers, and hammer on the wall? I dont move the old toolbox anyways, hasn't moved in 10 years.
and thoughts on tool walls?
jeeper46
Canton, Mi
I have a huge assortment of tools up on my garage wall. Since I'm usually doing something in the garage, or out in the driveway, it's just as handy to walk over to the wall and grab what I need. Also, if I didn't see some of my specialty tools right in front of me, I'd probably forget I had them if they were buried in some tool box.
bczygan
DETROIT! Arsenal of Scrappers
Nothing worse than pegboard on walls.
Junk collector and dust collector.
If you have specific tools, used with particular machines or work stations, put them there.
Everything else gets put away.
Bill
Mecha
Volunteer State
If you go pegboard, get steel boards and screw lock hooks. We used Viper brand stainless boards where I used to work and they worked pretty well. Square holes. I liked them and thought that they worked well when laid out and labeled well.
Cardboard boards and the non-locking hooks do ****.
Ign
Butte Peak ND
I used to have all my wrenches on a (big) wall w pegboard. I've been meaning to do it again. I LOVED it. Walk up to the wall, grab what you need. The downside is that it also effectively uses floor space - if you want to be able to walk up to the wall, you can't put anything on the floor there. But the same is true for cabinets w doors or boxes w drawers.
I seriously loved it though, so easy and convenient
LXCam
Back when my shop was a converted two car garage I had one wall with 16ft of peg board. Everything and I mean everything was loaded on that wall in perfect order. I loved just walking up to grab what I needed and with a moments glance could see if something was missing. And it was damn impressive looking as well. The only thing I lacked that was over the top was I would not outline the tools, that seemed taking it a bit too far. :)
I still use peg board above my clean bench area where I build cylinder heads and for parts storage. But the days of the collection being displayed and collecting dust in the garage are long gone.
Moose97
North Central Texas
I used to use pegboard and had all my tools hanging. It is fantastic for ease of use and seeing what you need. I came to this site specifically through the "Let's see your toolbox" thread because the pegboard system was driving me crazy! Almost every time you remove a tool the hook drops out. I've tried multiple different solutions to no avail. I still like the look of a nice, neat pegboard system but for functionality I've gone with boxes. Good luck!
Side note - I still have a few tools hanging on pegboard. Those are the tools I never use but my teenage son and his friends are welcome to them. Also the Mrs. can go out and use any screwdriver she wants to pry or dig from that wall.
crewchief888
NW indiana
Getting rid of a toolbox, and replacing it with pegboard to hold your hand tools sounds like a big waste of time to me.
I have some pegboard in my reloading room that the previous owner installed. It works ok for hand saws. And a few assorted carpentry tools that don't fit in one of the drawers under the workbench that was also left behind.
Pegboard ***** IMHO
:beer:
derosa
Oceanside, NY
Pegboard always ends up looking dingy to me, cabinet grade ply, a couple coats of poly and screws, look the best, brass screws for more style. Just lay everything out ahead of time, can add small boards with holes through for screwdrivers. Wish I had 12ft of wall space to do this with.
P
pfmg
Billerica, MA
Pegboard ***** IMHO
:beer:
The toolbox is going away because I need the space. I have a HF roll around that will stay. im adding real garage cabinets and moving stuff around to gain more front to back space. All the stuff in the craftsman box will fit in the new cabinets, but I thought while redoing the space I would add some type of wall storage between the new base cabinets/work bench and the uppers. Only stuff that works good hanging, like wrenchs, hammers, screwdrivers stuff like that would go on the wall. I thought it would pretty handy to grab these most used tools without opening a draw. This also frees up draw space for other stuff
jp828108
I took some pegboard down out of a garage that the pegs were wired with safety wire on the back side. Kind of a pain, but it kept the hooks in place obviously couldnt easily change or add to it.
I also personally like peg board/wall hanging tools. It frees up space in my tool box, and allows me to utilize the top of it as a work bench instead of having to add a top box. I use it for wrenches, screw drivers and other random stuff. I have each spot marked based on size. makes it easy to clean up at the end of the day for me. a drawer with proper storage solution would work too, but this currently saves me the expense of a top box.
My brother has Pallet racking for storage inside of his building. He hasn't done it, but we have talked about hanging a couple of sliding doors to hang pegboard on to be able to utilize that wall space and still easily access the storage racks.
BobsurUncle
Tracy, Ca.
Just removed 16 feet of pegboard from my shop wall. It was petty well organized, but still a catch all. Gave it and all the hooks and hangers away free, on Craigslist.
davethorik
Norka, Ohio
Place I used to live had a pretty big workbench in the basement made of 2x4, with pegboard hanging above. It was handy for things like pipe wrenches and adjustable wrenches, that kind of eat up useable space in a toolbox.
90zcar
There is peg board on the one wall of the garage that's on the property of the house we just bought. Not sure what I'm going to do with it but I like it for stuff that can't go in the toolbox like handsaws and big *** levels and tsquares
I may take it down tho and just add a nice sheet of plywood to which I just put normal screws in that I know won't rip out like I have seen peg board do
Motorman55
South Jersey
PEGBOARD GOOD
My double duty pegboard motor bench. It helps to separate my shop by creating a 'wall' where none exists.
Behind it is shelving facing the other side of my shop that's used to store lots of my wife's stuff out of sight!
2oolhound
BC Canada
12 sq ft of pegboard = about 4 drawers (26" X 18" drawers)
By upper and lower cabinets do you cupboards?
HF 42" or 52" roller cabinet with bench top will be better. Nothing like thin tool box drawers to hold things like tools so you can see them and they ain't piled too deep.
gungatim
west mich
I hate pegboard...and not a huge fan of tools hanging, but I still have a set of craftsman wrenches hanging above the bench from the days of not having enough room ...(now I am just too lazy to pull them down and don't have room for a 4th toolbox). even though they are a multiple spare set, they still hang there and don't get much use...but they are on scrap plywood with nails/screws so they don't waste as much space and don't fall down every time you pull a tool off...
Billy Jack
Pittsburgh Suburbs
I've been working with pegboard above my bench for 25 years and I'd hate to lose it. I'd need a LOT bigger roller cabinet if I had to stash away all the stuff on the wall and it would slow me down completing just about any job I come across.
My bench could see anything from a small appliance repair, a carb rebuild, a Lionel train repair or a small metal fab project, sometimes all in the same weekend. Things I want to access quickly are within reach without opening the Snap-On chest. Just as important, its quick and easy to put tools away, so you don't wind up with a huge pile of tools cluttering your work surface. In my opinion, the objective of tool organization is that you can retrieve a tool without having to move something else and a well organized wall display helps a lot in that regard.
Bill
90zcar
I think a piece of 3/4 plywood screwed to the wall would serve a better more quality purpose than pegboard
DTE
North Carolina
Every shop is set up different according to what you do. I have pegboard and shelves and cabinets and toolboxes. I have downsized and do not have the space I used to have and I like the stuff where I can see it. If you use pegboard find the good heavy duty 1/4 inch thick board and buy good 1/4 inch hooks ( they won't come out every time you touch them ) If I wasn't so old I would put it all around the top of my shop ( still finishing it )
crewchief888
NW indiana
PEGBOARD GOOD
thats a good use for pegboard, utilizing what would be a dead space.
i still hate it tho :lol_hitti
:beer:
ragdoll
I've always had pegboard over my main workbench in every garage I've had. I use it for the basics, everyday tools you routinely use. It's super convenient reaching up from the bench and picking it off the wall.
But the majority of my tools are in 2 toolboxes, as well as a few service carts.
JJThrasher
Indiana
If you don't have the space for a large box, peg board is great so long as its close to the work area.
We use pegboard at work for the lube techs. Basic metric wrenches, flip sockets, and filter wrenches all hang on it. There's a small Cman box next to it for the less common stuff and it filled 90% with garbage.
-Brent-
Utah
^ This.
^ This.
^ Or this would drive be crazy!
^ But so would this!
That said, I have had great luck with Wall Control's metal pegboard. We used it in our utility room and I just put some in the garage. It's not for tool box items, though. I ordered a few fixtures to accomplish what I want but it's really not for stuff that I would put in a box, ever.
driftpin
Growing up, my dad had pegboard above the sturdy workbench that we had at two houses. It wasn't loaded with tools but it served a purpose.
It wasn't until recently that I had a dedicated space for a garage workshop. I chose to use Whirlpool Corp.'s Gladiator track system which mounts to the wall, 6" wide x 4' long w/continuous horizontal channel slots for using a variety of their storage products. The Craftsman Geartrack system is similar, and I've found the dimensions are similar enough that the removable storage brackets are interchangeable. I actually prefer the Craftsman Geartrack brackets because they have a 90* throw locator lever that locks the hanger in-place (top & bottom) more-securely than the Whirlpool Gladiator design.
I have an 8 ft workbench frame w/a 1-1/2" solid wood top, and that's topped w/a 3/16" steel sheet, held to the frame w/countersunk 1/4" flathead machine screws. A decent vise mounted to a 2 x 8 scab of wood held in place w/a sturdy c-clamp (removable if I need to), next to that a swiveling magnifying lens, lit by a concentric circular fluorescent lamp, w/an additional movable loupe, and that lamp pivots on its mounting pin drilled into the vise wood piece.
At the other end I have a 6" grinder, one stone, one wire wheel. I had to source a good American wire wheel because the offshore ones would make the grinder jitterbug around because of the crappy balance, or rather the lack of balance, the USA wire wheel was close to $40 but worth it. I also don't end up looking like a porcupine from the shedding bristles of an Asian one.
Underneath I have Craftsman roller cabinets, two are 4-drawer units, two are two-door units. If I needed to I can move them all out from under the workbench in perhaps 90 seconds, which I do periodically to roust the 'daddy longlegs' that appreciate the space for housekeeping.
The tool hangers I have on the wall carry a bunch of things, metric and SAE combination wrenches, hung on a Craftsman plastic snap-in tool tote; hanging on two long pins, a blow-molded plastic box for a 1/4" drive socket set; and various brackets for frequently-used hammers, pliers, and screwdrivers; two 19.2 volt battery chargers so I can remove the battery, and just press it 'into' the charger receptacle, and remove it just as-easily, with a firm 'pull,' which keeps the workbench free of charger clutter, and fresh batteries directly in-front of me; a 3' shelf mounted up high, well-above my head, for storing a variety of whatever I need stored, short-term, I use some of my wife's discarded baking pans here, because they come w/snap-on plastic lids to ensure no parts go missing; the front of the shelf I have mounted a US General magnetic strip, where I hang my wire cutters, 1/4", 3/8" and 1/2" 5/16" hex to square drive adapters;back on the wall I have multiple plastic clip-in bins for holding spray cans of WD-40, PB Blaster, Sharpies, pencils, tool receipts until I don't need them, work gloves, some ratcheting strap tie downs, and some kept empty to collect small parts from whatever I'm working upon, until they are retrieved; and some different Vise-Grips for fabrication or clamping. I don't do a lot of welding, but I've got a light duty stick welder, a flux-wire welder, and an acetylene 'trench tank' setup for on the job soldering, and an oxy/acetylene cutting torch stored elsewhere. No welding table yet, not sure I need one for the amount I do. I also hang nut drivers clipped into a plastic carrier; a cloth roll hung from grommets for punches and chisels; and a drill index. I also have a selection of adjustable wrenches on a common pin, and pipe wrenches on a common hanging pin.
Above the wall storage I have a welded steel Gladiator 30" square x 12" deep two-shelf cabinet tapconed to the CMU wall, and underneath it I have a 33" LED light strip. I have three double-duplex 120 V outlets above the workbench, and a 240 V 20 amp service receptacle for saws or welders.
I have a HFT auto-retracting 50 ft. air line from my 240 V compressor above one end of the workbench, plenty of length to reach out into the driveway to air-up tires, or to blow away leaves from the driveway.
What I have hung on the wall are tools I use frequently, I don't keep a valve-spring compressor there, that's in a toolbox, along with other specialty tools and supplies, and I have several stackable toolboxes that are of-course, roll-arounds. I don't need a 5 ft long box, 5 ft high, to be in the way, space in my shop is at a premium. I can push/roll all my tools into one bay to give me an open 1 car space, if I needed it, but the vehicles stay outside, hey, it's south Florida. The exterior wall opposite the tools and workbench is also Whirlpool Gladiator product but it's pallet-style shelving, originally 18" deep, I cut them down to 13" depth, so they don't protrude into the garage OH door space, as my returns next to the OH garage doors aren't much-more than that. I store smaller portable tools like wood and metal chop saws, gas welding tanks (small ones), a combination belt sander/disc sander, a benchtop scrolling saw, and numerous smaller portable toolboxes holding hand tools and supplies for various types of work. Every three ft. I have a duplex outlet about 46" high, for three sides of the garage, and a double duplex between the two front single OH doors about 16" off the floor, and another at ~7-1/2 ft. for a shop lamp hung below the OH door tracks, between them.
I have a 13' x 20' loft at the rear half of the garage for storage, and a hydraulic 360 degree pivoting 'cherry-picker' to allow me to get heavy, bulky items up or down. It's my 'loft-lift.' I adapted a 120 V electric winch to the 'cherry-picker' and the two pieces are rated at 2,000 lb. for their short length and double line pull, and 1,000 lb. for an extended boom length and a single-line pull. The loft was designed for hundreds of pounds per sq. ft. and it has a front steel box beam of 4" x 8" x 1/2" welded to flitch plates set into the CBS walls on either side, for the loft floor joists to anchor-to at the open end, and a CBS wall for the ledgers on the opposite closed wall. It was all done by an architect and structural engineer. There are no stairs to the loft, and the headroom isn't quite 5 ft at the ridge beam which tapers to about 3 ft at the sides. I would have liked a full second story, but we didn't have the $$$$ and the stairwell to it would have taken a good deal of floor space, and made it a 1 car garage w/less than a 1 car space next to it. Compromises. I have motorcycles as a hobby, and the loft gives me space for secure, dry conditioned storage of parts and other household items. I put shelving above the high-lift OH garage door tracks for light, bulky storage, perfect for Christmas decorations, and long building material, or unused storage containers, nesting in one-another.
For me, the advantage of the wall storage is that tools I use frequently are an arm's-reach away, no drawer to open, and easily replaced. I can inventory the tools at a glance, and see what's still 'out,' and what needs to be replaced. It works for me. If you like a six-foot long Snap-On cabinet five feet high, this isn't for you. My entire tool inventory probably wouldn't buy one of those monsters. But, I've maximized my space, and can easily accommodate shifting things around as I change needs.
I also use the space between the bays of the loft. I used 1/4" masonite fastened to the bottoms of the loft floor joists to provide storage, I chose 12" as a good depth for each bay, the anti-racking reinforcement scabs of wood between the floor joists and the masonite make perfect compartments for HFT plastic bins to fit two-abreast in the compartments. In other loft bays, I installed cast-iron shelving irons to support pipe clamps and longer metal stock. Another couple of bays house my 3 ft and 5 ft levels, hung from exterior-grade screws.
The back wall of one side of the garage holds three 30" square x 12" deep Gladiator welded-steel cabinets. They are mounted ~54" above the slab so the vehicle can comfortably pull forward. The wall is CBS, so they are mounted via tapcons w/flat-washers and a ledger beneath. The Gladiator cabinets have two adjustable shelves and steel pegboard strips on the inside of the doors. I use the pegboard to hang masonry and metal cutting discs, pneumatic power fittings, containers of fasteners, and whatever-else I need stored, and found easily by opening a door, at-a-glance.
I have a pneumatic platform lift for my motorcycles, a Handy Air Lift, and my back thanks me.
My space is constantly evolving, as I think of something I can easily change the layout, and inspiration comes from reading fellow members' posts. As has been said, necessity is the mother of invention.
jeff64
I use 3/4 plywood walls and 2 inch finish nails. It's about as cheap as you can get and it holds some heavy tools. I don't worry about it getting brittle with age like pegboard. If the finish nails aren't enough, you can always step up to 16 penny nails.
bdelmar2
I'm not real hung up on one way or the other for tool storage, I do whatever is best for the situation.
Hanging tools isn't something that will work with most of my stuff at work, but I do have some of the higher use tools on magnetic holders next to where they are used, but mostly in the boxes.
Now that I own my own home I will be more likely to hang stuff, its less likely to disappear and I don't mind putting out the extra effort for something I own.
Somewhere there is a little video showing a system that I thought was pretty cool.
Uses something they call a 'French cleat' I believe.
Basically you rip a sheet of plywood into about 4" wide strips with the blade at a 45 degree angle.
You then attach these strips all around your walls about 16 inches or so apart with the tall side of the 45 facing you and pointing up.
The cutoffs become the other half of the bracket.
Kind of hard to explain, but it appears there are lots of French cleat videos on utube.
Couldn't find the one I originally saw, which I think was a better setup than what I could find this morning.
The guy in that video had his whole garage done with them, and just screwed them through the drywall into the studs behind.
But the cool part is you can swap whatever you want in wherever you want as your needs change.
Could be a board with a set of wrenches, could be a cabinet, could be an open shelf, could be hangers to store wood or metal, brackets for power tools, or some of them even double up the cleats and put tools like bench grinders, small drill presses, small band saws or whatever on them. I imagine you could also do pegboard sections with cleats also.
And you could completely switch it around in a couple of minutes.
I don't particularly recommend this video, I just grabbed one at random to give people a quick look, but googling 'French cleat' brings up a lot of options.
rhandwor
I run out of space so I put some 2x4 with spikes for large wrenches over 1 1/14 inch.
fatfillup
Finksburg, Md
I am surprised by the amount of dislike for pegboard. I have always had it above my benches and wouldn't trade it for any other storage system. I have boxes also as well as a tool cart. I just think it is handy.
For they guys who complain about hooks falling off, the hooks with the extra stem to stick into the hole below work great. And you guys just gave me an idea, for the hooks without the extra stem, and I have a few, I am going to put a drop of hot glue to keep them in place.
ndr1968
Oklahoma
My pegboard. How do I love thee! Let me count the ways!
The weak link in any pegboard system is the hooks. I recommend these: American Tool Exchange Professional 8” Peg Hooks, Catalog #34102. I think I got mine @ Amazon at the time but didn’t see them just now. They are available here though:
https://jet.com/product/detail/3825...609283_pla-156851101500:na:na:na:2&code=PLA15
https://www.walmart.com/ip/100-Pc-8...4438&wl11=online&wl12=116763729&wl13=&veh=sem
I can’t stress this enough - you need good strong hooks! The 8 inchers are a good size. They can be cut down and if the knob on the end is a problem, those can be easily removed also. As testament to how well these thing work you can see that I have a saws all hangin' from one fer pete's sake!
I like my peg boards. I do have a vintage Craftsman tool box my dad left to me as well as a 4 drawer cart, another roll around cart loaded with shop press tools and a bin rack on wheels from HF for really small items. But for the items that I don’t use very often and especially those small items that I use just enough that when I need them they have been “put away in a safe place” so good that they are pretty much gone and have to be replaced…well, that’s where my pegboards have really come to shine.
The pegboard over my layout/work table also holds my go-to tools. There’s a set of SAE and metric wrenches hanging there by single hooks (To use this setup see this post http://weldingweb.com/showthread.php?25351-Home-made-tools!/page29 please scroll down to post #722). I have a full set of SAE and metric spin tights hanging there as well as dead blow hammers and a couple of ball peens. Also, box knives, scissors, pliers, a cut off grinder, dremmel kit, wire brushes, dust brushes, replacement drill bits in the smaller, “disposable“ sizes…see the photos please.
On the storage board you can see there are several items to a hook. It looks a little sloppy but the thing is, when I walk over there, it’s pretty much all visible and easily accessed. No rummaging in drawers or cabinets where most of the small bits get buried and hard to find. The small, loose stuff I put in Ziploc bags and hang those.
gte718p
I'm generally in the hate peg board category. However, I bought some of the wall control metal peg board and hung it by my bench. Having the tools I need quickly at hand was very nice. It do a lot of electronics at the bench and have about two dozen sets of little pliers, crimpers, cutters, and screw drivers. I found hanging them back up after I used them made the work bench less cluttered and easier to work on. The tools were always right where I need them, instead of searching the bench and find the crimpers under a box somewhere.
snapmom
Florida
Wood back, 1-1/2 strips between the wood and peg, so you can use nails and hangers. Pegs work well with workbench.
bobcatdan
Kaukauna,WI
Use pegboard or all the stuff that is awkward in the toolbox and hangs well
