Tools you always had but never used
dscheidt
dwasifar
Security allen wrenches, Conduit bender, wood chisel, metric dye set, soft metal tubing bender, wood plains, heat gun, tire tread wear gauge, IC chip remover, chalk line holder, alligator clip jumpers, Feeler gauge, instruction manuals, metal files, and my engraver.
But the minute I sell or give them away, I am gonna need it!!!!! :cautious:
I use my conduit bender and tire tread gauge regularly.
Meursault74
Southern California
I dont understand those. You cant put any meaningful down pressure on the head due to the design. Thus if the screw is at all tight the driver just cams out.
What can they actually be used for successfully?
I have one of right angle opposing screwdrivers. But I had to buy this. This was actually a lower profile than the one I had which didn't fit into the gap.
I had to replace the igniter for my home furnace. Small Phillips head sheet metal screws held it in place. Easiest way to access it was with a right angle screw driver. That harbor freight tool just made it into the gap (a gas pipe was right above where it was screwed in). Screws were not torqued down super tight. So this tool worked fine. I'm not sure how else to get at those screws without disassembling other parts. A right angle screwdriver is the tool for that particular task.
Igniter
Those igniters are made of fragile material, so you have to put them in carefully.
Peter Burritt
Central NY
Those right angle screwdrivers with a Phillips on one end and a slotted on the other. I have probably a half dozen, I don’t know where they came from, and I’ve never used them.
I have one made by Vaco that I have used a few times. Case IH machines are full of smooth round-head slotted fasteners that are a pain to get off. They aren't carriage bolts (like John Deere machines use) and typically just spin if you try to get the nut off from one side. In tight areas where these fasteners are located I put the right angle screwdriver on the slotted side and ratchet on the other and cross my fingers that there isn't too much torque for the screwdriver to handle. If that doesn't work (Which is 90% of the time) I just go and get the torches.
freudianfloyd
Nowhere
Kobalt gear less ratchet. I thought for sure I would need it, but it has never been used. You don't realize how important the ratcheting feedback is when using a ratchet.
My Snap on tools. I never had them growing up, so got accustomed to my other brands, and now that I have them, they are too nice to use so I just collect them and look at them. I try to use them, but they just never seem to be the tools i grab. Even though they are great.
Ignition wrenches. I have two sets and have never used them, and to be honest, I dont even know what they are for.
Air ratchets, have a few, never think to use them.
End cutters. I have atleast 5 pairs of all different sizes and have never used one.
tyyost
Tunkhannock, PA
I have a 3/4” Snap On ratchet that I bought at a garage sale dirt cheap, and a bunch of big 3/4” sockets. I have yet to use any of them more than a couple of times (at most) since they were purchased, but I’m still glad that I have them. When you need that big wrench and socket, there really is no alternative.
Same here, I‘ve used my 1 1/2” a few times other than that I use them more on my shop press than on fasteners.
RedneckWelder
The Ghetto Kingdom of Methlandia
For me it's vise grips. I probably use vise grips once a decade. I think I usually cut or grind it if I can't turn it. But way early on in my pre teen wrenching years everyone had a pair so I bought mine from Bradlees and added it to my collection.
Vise Grips are one of the most useful tools I own, but I don’t hardly ever use them for their intended use. Just like I never use adjustable wrenches on normal bolts and nuts- they work great on plumbing, hydraulic lines, or bending thin metal.
Madjik Man
This is my entry.
I have a set of ignition wrenches that came with my Craftsman mechanic set.
I think I only ever opened the pouch once or twice to look at them. Other than that they’ve never been touched.
I know what they’re used for, I just never have to grab them.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Dwasifar. Hitachi scope sleeping
qSomeone gave me a Hitachi oscilloscope once, and I never used it in the 10 years I had it. Don't know if that qualifies.uq
I am the happy owner of a 2 channel 20 MHz smaller Hitachi benchtop scope. Really good. Made 1989 and still perfevt. It has a built in NiCad accumulator with internal charge circuit that lasts around 1 hour.Amazingly, it is the original accumulator, date stamped october 1989 and no leaks, full power.
If you feel like getting rid of your sleeper Dwasifar I would be most pleased to buy it. But, freight to Sweden kills the prospective deal.
Ola
  • mini-Telefunken med mek vib switchning av 6 V Perfekt Måste varar Mallory Goldtop vib inop i e...JPG
autobon7
Adjustable wrench for sure......cannot remember last time it moved. Very early Gearwrench pass through ratchet/socket set. Sold it a few months ago.
Robinson1
Kentucky
Havent used my 1/2" air inpact in atleast 2 years. Always grab the cordless one.
Have a palm nailer thats never been hooked to an air hose. Bought it for a project that never happened.
Ive got a Tekton master set of 1/2" chrome sockets. Not a single one has ever turned a bolt.
nadogail
Coronado, CA
I bought some Clutch Head screw drivers during the 1950's, they see almost no use; once a neighbor with an older Chevrolet Station Wagon wanted to work on his tail lights and he had never seen a Clutch Head Screw before.
RJMadigan
Over the forty plus years that I turned wrenches professionally I think I used everything on a more than once basis. The only exception being nut runners. Never did seem to take those out of the box so they're the shiniest tools I own. As others have said the Matco 3/8" air ratchet was a waste of cash, never did use it much, slow and weak. Had a cordless 1/4" ratchet that was a waste of money.
Now that I'm retired I have to go through the drawers on my big box just to see what I have. Don't use much of it regularly now but I'll be damned if I'm getting rid of anything because, well, you never know, right?
isb cornbinder
I bought a Walker Turner band saw welder. It appears to be almost never used. I have never used it.
Make me an offer and it could by your new shop machine. (maybe)
Milton Shaw
Piston ring compressor and grove cleaner. Used it once nearly 50 years ago. Others I don't use anymore are Ford upper control arm alignment tools used on 65 and up large Fords. I have bought tools to do just about any job a good DIY're could use. I have tools for carpet work, drywall, painting, concrete, siding, metal working, welding, machining, plumbing, some electronics, sewing, and many more areas. I bought a Ridgid Pipe thawer for $5 without cables. Bought the cables and haven't had to use it since although I came close at a friends house,(got her to use an old electric blanket on the frozen area next to her drive way.) Lots of money ******* in tools and just about to the point of trying to sell some of them. But not yet..
ecotec
Electricians use nut drivers often.
Al Borland
I've got a hammer. It was my Grandfather's, My Father broke the handle on it. My (deceased) brother put a new handle on it in shop class. I have it, but, it's not for using.
davethorik
Norka, Ohio
I picked up a snap-on sll80a number of years back used for a good price, and took it to work. used to use it a lot more, it did a great job and I like using it. but i moved departments now it pretty much is drawer jewelry in my box. getting rid of it? heck no lol
dchawk81
I've had a brand new engine stand for probably 7-8 years that's never seen a power plant. The project it was bought for never transpired.
MJK
Tucson, AZ
Stubby ratcheting wrenches. Bought them 15 years ago. Tossed them a couple years ago. Could have used them today. But I kept the crows feet!
rharman
SoCal
My unimat lathe. It's cute, and looks nice, but never found a good use for the thing... not powerful enough to do firing pins, so, well... it made a good dust collecor.
I've always wanted one of those. I have NO idea what I'd use it for... Just always wanted one. And, the mill too.
Junkman
Northeastern CT
FH80MP - I have all three 1/4", 3/8", and 1/2" and they have saved me more time than I can remember. My only fear is that I will break one and not be able to get a replacement for it. I didn't know that Snap-On has come back with them.
