Still down.
Cripe still down also.
Yes and still nothing.Checked it from a couple fo different networks and it's working fine, so it must be a regional thing.
Did you try by using the IP address I posted above instead of the name?
Were you able to order and get confirmation? Is it a go?Checked it from a couple fo different networks and it's working fine, so it must be a regional thing.
It's a weird problem with the catalog.
If you go through the drill-down menu on the left you can't find anything because the categories will all be empty. But if you search for an item by name you can still find things.
Let us know if it works. Google the item. Put in the descriptor and toolsdelivered.com in the search box. Find it. Click on it and voila you are able to see it and put it in the cart. I think the blank page under the category is "all gone". They didn't close all the loopholes, but looks like most everything is "backordered" for 30 days or more.Thanks for pointing this out. I just checked where I had bookmarked their screwdriver set and saw they're on sale!
$78 for 19 pc
Greyson
I would not order from them as they are obviously having some issues and trying to loop hole an order does not seem kosher to me. Check out other Williams vendors like industrialtoolsupplydenver.com
"Loophole" I think was a work-around if their site was having problems/glitches. Most thought it was a site problem, not realizing that the blank pages meant no stock. The issue seems to be that of no stock. Many of us thought it was merely a technical problem and were messing around with work-arounds. That was obviously not the issue. Almost everything on back-order. No work around or loop hole for no product.
Looks like they are back now.
Cripe is still down.
"All the items you ordered are on backorder for at least 30 days. The future availability date is unknown at this time so your order has been canceled.The website is back and many items says they're in stock. Do you have any actual proof that they're out of stock of everything? Perhaps the order being canceled was associated with the website problem?
Perhaps we need to contact them through their site or on here before making too many guesses.
http://www.garagejournal.com/forum/member.php?u=77836
We will place you on an automated email notification list for when the items become available.
Thank you for your business.
I am sorry about this.
good enough proof....?
Correct...just bad luck on picking out the over half dozen hand tools that were 100% out of stock at the same time their website had problems. I will probably be persona non grata at their site in the future.No. See my previous post. The site is back. It's not clear if you cancellation was connected to the website problem or not.
They also have a lot of things still listed on eBay.
