Top 10 HF tools
Farmall450
Marengo, Illinois
Don't think I've bought 10 things that I've liked but...
The Black & Yellow 5 pack of leather work gloves (for the price, unbeatable)
Soapstone Pencil Combo Pack (Square & Round) Note, both refills were cracked
Old set of Pittsburgh screwdrivers were actually decent,
Next time I buy Impact Sockets I'm going with their Pro's.
NWphotog
44" top and bottom chest
Roto ratchetsh
Multi tool
$2.99 led puck flashlight (love it!)
Breaker bars
Mechanic work gloves
Dead blow hammers
Freebie multimeter (always have one in the truck and tool bag now)
Pry bars
High volume horn
Lots of other items but that's a good start.
crewchief888
NW indiana
I bought the panel welding clamps, but I haven't used them yet. anybody else buy them?
and some magnetic welding angles
Walked through there the other day, and couldn't talk myself into spending any money.
i bought some of the panel clamps last week, but havent used them yet, their magnetic welding angles dont seem to have much holding power IMO
Anyone tried their A/C Manifold Gauges?
buddy of mine has a set, the couplers on the ends of the hoses are not the greatest.
The tire mounting fixture. It isn't the most complicate tool...but it works!
Between using it on cars, and on motorcycle tires, It has saved me probably $1K's of dollars. The racecar and motorcycles go thru many tires!
i grabbed one of them on sale about 3 years ago. saved me a lot of aggravation busting tires to scrap the wheels,
swapping tires and wheels on my trail truck. i've had great results with 33"-35" tires, not so much on some lower profile stuff, with stiffer sidewalls
orange 4" grinders
black 11mil disposable gloves
3" air cut off tool
mechanics type "impact" gloves
6t jackstands
:beer:
pacecar
bryan, tx
I got an air compressor for x-mas, went by to get me some goodyear hoses, all they had left was the 25 footer
The folks stocking told me they will not be carrying anymore goodyear hoses, so get em while they are there, i'm gonna have my brother check a couple stores around San Antonio to try to score me a 50 footer
cmandp
New Jersey
HF's toolboxes for sure, the 26", 44", 56", the single drawer, the gloss black and 5 drawer carts are great for the price.
I think their plastic socket rails are great too. They work better than metal rails and are still reasonably sturdy. They're so cheap I don't mind modifying the length for each socket set.
Davefr
OR
The only "real" tool worth buying is the plastic ratchet. It's hard to explain but it's actually nice to use for everyday tasks.
The 2.5L ultrasonic cleaner is also pretty decent.
Other then that it's stuff like tarps, gloves, bungee cords, etc.
Never forget the HF shopping rules:
- Don't buy anything that cuts
- Don't buy anything with moving parts
- Don't buy anything with an electric motor
- Don't buy anything where failure could be a safety issue.
- Don't buy anything that measures
- Don't buy anything that you may need for a second time
woody 73
The Great State Up North
More with Honorable mention:
I don't remember the name and I no longer see the product but it was an empty Aluminum bottle that you filled with any liquid and then you just added air from your compressor or used a bicycle pump...fantastic wish I had bought more!
At one time they sold little SS jars that had a see-through lids I think they came from Pakistan, but those little suckers are very nice with holding small bits and you could just look at the top and see what each jar held; I no longer see them.
Someone said the Blue gloves but I find they wear out very fast (cloth gloves); on the other hand if you can find the gloves that can hold up to the chemicals without falling apart they are a good buy;something like 50 to a box.
They made a blue plastic Movers dolly and that sucker could hold a ton of weight trust me I moved 800lb. machines all around my shop with no problems.
They made a knockoff of Eastwing hammers that hold up ok, I think they still make them under the pro name.
Now for some not so Honorable:
The plain Jane Bright orange Electrical pliers darn those teeth crush in an instant, maybe some have had better luck but not me.
The vise grips are like tissue paper don't get me started.
The drill bits I think they made out of extra ply waste products (but some people might like them).
Screwdrivers are a hit and miss some are ok and other are not so good.
hope that helps you out.
NWphotog
I agree many of their screwdrivers are horrible. I do think the orange and green pros are a very good value. I believe they recently changed the colors.
Trey T
Houston, TX
20 Oz. High Volume Low Pressure Gravity Feed Spray Gun Item #66222
and 1/2" impact wrench earthquake (1st gen)
jbighump
above tn but below oh
1/2" breaker bar
gloves
hook and pick set
paint markers
air fittings
oil filter pliers
vaccum pump
free screwdrivers the wife loves these
roto ratchets
earthquake air tools
and most air tools are good
Larwyn
Texas
My list is easy, these are the HF tools which have given satisfactory or better performance. Some of them are modified to some extent, others are bone stock. These are the ones that I use often.
1. 4 x 6 Horizontal/Vertical Metal Cutting Bandsaw.
2. 16 speed Heavy Duty Floor Drill Press.
3. Compact Bender
4. Throatless Shear
5. 110 pound anvil (The old Russian made one).
6. 20 ton hydraulic press
7. 1000 pound Hydraulic Table Cart
8. 2 ton foldable Shop Crane
9. An older model vise simialr to thier current 5" Multi-Purpose Vise.
10. 12 inch Disc Sander (the older green model).
steel 35
Between the PNW and the Emerald Triangle
Three inch die grinder
Wrenches
3/4" ratchet set
Like my three 13 Drawer boxes.
AS mentioned I won't try pliers or anything that grips or turns screws anymore.
And these are a must for my shop!
91bronc300
mrpizza
IL
1. 25 inch 1/2" breaker bar
2. 1/2" Earthquake impact gun
3. Goodyear air hoses
4. Four piece orange handle pick sets
5. 3" air cutoff tool
6. The drill master 4 1/2" angle grinders.
7. Pittsburgh pro impact sockets
8. The 2 ton low profile floor jack
9. Goop hand cleaner
10. Step bits
I love the grinder as they can be had for ten bucks. I get it with the two year extended warranty for an extra five bucks. Basically free grinders for two years. I rarely burn one up though.
NC-Fordguy
I've had good luck with.....
Impact sockets
20 ton shop press (I did break an arbor plate)
240 volt compressor
torque wrenches (I used these primarily for wheels)
Locking extensions
24 in breaker bar
vacume brake bleeder
step drill bits
die grinders
HLVP guns ( spraying primer and jamb outs)
not so much with some other things though
cheechi
Triad, NC
I think I saw those sure shot style on a recent trip in there. I wanted one, but settled for one of the old style squeeze pump oil can style. It was just for WD40 but I have been meaning to get one of them anyway.
SteveL
St. Louis, MO
Here's my list that has worked well:
HVLP spray gun
Dead blow hammers
6" bench grinder
Framing nailer
Air staple gun
25' hose reels - have 4 of these
Hearing protection ear muffs
Hydraulic roll around stool
4 ton Bottle jack & drill press vise - made an awesome golf club head extractor from these
Casters
20 gauge wide crown stapler - air version
Speed square
Compound sliding drill press vise
Bearing puller set
4" cut off discs
Probably have some others but can't remember off hand. Considering getting a couple of 44" tool boxes to go under a new bench.
Cedge
Greenville SC
1000 pound lift table..... like having 2 extra hands.
56" Roller Box................ I can actually find my tools now.
Titanium Nitride End mills.... Cheap, tough as nails and cut great.
115 pc. Titanium Nitride Drill index.... Cheap, accurate and quite durable.
115 pc. Cobalt Drill Index.... Self centering, accurate and very durable.
Green Tool Grinder..... Sadly, discontinued, but this thing is a beast.
6 and 8 inch Digital Calipers..... Accurate and cheap enough to have several.
Aluminum Racing Floor Jack.... Light weight, low profile and works exactly like it should.
3 ton Jack Stands..... heavily made, well designed and very dependable.
1" Belt and 5" Disc Combination Sander.... Tough little ****** that just keeps going and going.
4 ft 12 socket power strips..... Heavy duty with a lot of quality for the price
Didn't realize just how many good long term usable tools I've gotten from HF.
Steve
Hammer1963
Kentucky
Black 4 drawer tool cart
Titanium Nitride step drills
1/8" double end Titanium Nitride drill bits
Orange dead blow hammers
Mig pliers
2 part epoxy
No longer available HF Pro 3" DA (mine is 15 yrs old and used weekly)
1/2" breaker bar
Chicago Electric 3" cut-off wheels
acdc73
I keep hearing about the HF step drill bits - I'll have to get some and see if they hold up
Exceller8
Banning, CA
15 piece metric & SAE service wrench sets
Red shop rags
The service wrenches are so good they are the only ones that get to play with my other American made stuff. :D
Mike662
Colorado
I don't have 10 items on my list, but I have their self-retracting air and electric reels, and I am more than satisfied with both.
Plus the 44" toobox, discussed at length here on GJ. Excellent value for the money, IMHO.
$9 heat gun, works for my purpose (mostly, heat shrink tubing)
jweller
1) Best thing I bought there was a tile saw.They don't carry it anymore but it it is this one I have done a ton of tile work with it and it keeps on ticking. I did not buy the blade at HF thought.
other stuff
2) the hooks and picks
3) tarps
4) the 6 pack of split leather work gloves
5) step drills
6) the nut and bolt storehouses - I buy them if I see them on sale. and they have saved me a trip a number of times. Obviously not grade 8 or anything, but its a good cheap assortment.
7)Casters
8)the oscillating multi tool - I bought it because I wasn't sure how much I would use it, and figured I'd try the cheap one to see how useful it was, but I use it all the time and it keeps going. Louder than a bomb though.
9)12 ton press
10)the LED puck thats always on sale for like $3. Picked one up and I can't believe how bright it. and it's got a hook and a magnet so you can get it where you need it. lotta bang for the bucks
ambenz
NW Chicago Suburbs
I have to say I am satified with all these things I bought.....
D
Danglerb
SoCal
Can this be used with a bit capable of drilling 1 1/2" holes into rock?
I have a bunch of rocks in the canal behind my home I've been trying to remove to no avail. I'm considering using expanding grout (expanding cement) which requires a series of 1 1/2" holes to be bored.
Tipsy
1 1/2 you might need to step up a model, but I haven't seen many comments on rock drilling, only concrete.
http://www.garagejournal.com/forum/showthread.php?t=23829
http://www.garagejournal.com/forum/showthread.php?t=37460
