Top 5 Tools Every Man Needs
geologist
Hammer
Socket Set
Multimeter
Torque Wrench
Multi-tool (Victorinox or Leatherman)
Some part of me wants to say my Dad's favorite 5.... (RIP)
Beer
Cutting Torch
Hammer / Sledge
Welder
Pry Bar
ArkTinkerer
Multitool with pliers.
4-1 or 6-1 screwdriver.
Multimeter
hammer
hacksaw
Can force your way thru most projects with these. 6-7 would be an adjustable wrench and/or smaller pipe wrench.
ArkTinkerer
M
Mechgineer
LA, California
Since I started this thread thought I'd throw in my 2 cents.
All industrial sized man tools for a *lazy* manly man:
Tire Changer and aligner (counts as 1 sometimes)
4 post lift
Parts washer
Easily Cleanable floor
and... Well... Beer. :beer: Cheers!
spity
Baltimore, Maryland
All Macgyver needed was a piece of bubble gum and a paper clip.
Mine;
-Fire
-The Wheel
-Knife
-Rope
-Education
With these skills I could rebuild civilization.
Larwyn
Texas
For the garage? This is easy:
1. Oxy/Acetylene torch.
2. Good Vise.
3. Anvil.
4. Six pound club hammer.
5. Smaller hammers.
mkoronka
Bakersfield, California
Socket set 1/4 3/8 1/2, screwdriver set, plier set, set of hammers all types, bench vise. Most minor things can be done with these tools. I know they are more than 5, but are 5 catagories. Men should always strive to get every tool they can get except for the novelty tools. I try and get a new tool each week wether it is an upgrade or an addition. Stay away from HF tools if possible. Mostly junk. Consumables are okay like grinding discs and sanding supplies. I still prefer USA made wire brushes, they are getting hard to find.
knocker
Peoria, Az
my vote,
sawzall
duct tape
muti meter
screw gun w/ self tapping screws
cresent wrench "adjustable wrench"
Rico.
England
Supersonic Nebuliser
Hyperdriving Accelerometer
Multispatial Transpectographer
Unidirectional Multiphasic Thermodynamilator
Superpulsating Hydrorganic Duomagniflator
Never go anywhere without these essentials...
Butters
I'm definitely with the "Basics" post:
Claw hammer - you can frame, finish, pull nails, hit a punch/chisel, or just plain whack the living s*** out of something
Crescent Adj. Wrench - aka poor guy's wrench set
Channellock pliers - something to hold the other end when your "poor guy's wrench set" is holding the other side
Phillips screwdriver - which will probably get used as a punch at some point
Flathead Screwdriver - aka chisel, prybar, paintcan opener, etc
*Handsaw I know, that's 6, but some things need cuttin'
2nd Tier Needs: sources of light, fire and beer
KermitFrog
NW Florida
1) Boxcutter
2) Rope
3) Tarp
4) Shovel
5) Duct Tape
With these 5 tools you can do anything and get anything.....or get rid of anything if you wanted to. :)
greasemonkey44
memphis
flash light
pocket screw driver
dykes(diacs)
hammer
normal flat bladedscrewdriver
those are the most used things at work; and to me the most essential
TEXACMAN
Mount Pleasant Texas
1. Good Lighting.
2. Sawzall with metal and woodblades.
3. Unibit.
4. Angle grinder with grinding disc, cutoff wheels , wire cup brush.
5. Drill press.
In no particular order.
:pimpflash :beer:
mayhemman
HAMMER
4 IN 1 SCREWDRIVER
PLIERS
BIG PRY BAR
CALF PULLER
BOTTLE JACK
with these minor tools alot can be acomplished.
Jwrightkustomz
Salt Lake City, Utah
1. A vague idea of what you are doing.
2. Angle grinder
3. Welder (no particular type)
4. Screwdriver asst.
5. Pliers
Now that you are done with your first attempt....
1. Internet
2. Tape measure (to figure out where the f*** it went wrong)
3. More welding rod (or wire)
4. New screwdrivers since your old ones broke when chiseling
5. Band-aids
Common sense is the most important tool/safety gear you will ever own. That and of course..... A BIG F****** HAMMER.
beardog
The first 5 that came to me are: hammer,pliers,saw,measuring tape, and a screwdriver(I'll cheat on this one...4 way multi bit). If pressed I might trade the tape measure for a light.
Caveman style: knife, flint, axe, and...
oh ****, just give me two hammers!
plumber84
England
10" Adjustable wrench, 16oz claw hammer, retractable blade stanley knife, 10" water pump pliers and a multi bit screwdriver as a basic requirement.
toolfanatic
Ireland
I'd agree with most of the above but I'd like to add a 12" hacksaw frame and blade to the list- as well as cutting metal it can be used to cut small sections of wood or plastic. No power cords, easily controlled and no special safety equipment required!
