Top chest options- help
tarbellb
Oregon
I'm building a custom welding table and would like to utilize the space underneath for my hand tool storage
Box height is limited due to a 8" thick (tab n slot) table top
Thinking anything up to 22" high is viable
_ no pop top versions as I wouldn't be able to use that space
_ width from 40ish to 72ish
what's a good economical option, Icon is ideal but the pricing is more then I'd like to spend
Any other option I should be looking at?
Snapped-off
Indiana
Would the Icon even work? They're 25" high. 20% coupon might take some sting away
RMERR
Northern CA
Unless you're set on "new", you might look into a used box. CL or FB marketplace always has lots of chests and top boxes. Might find just what you're looking for and save a buck as well.
T
tarbellb
Oregon
I'm in a small used market, most searches don't turn up many options. I'm pro used, but this is a narrow scope usage
Looks like you need an intermediate chest rather than a top.
Not well versed in tool chest, what's a intermediate chest?
Thanks guys, keep the suggestions coming
Not a roller, not a top with a flip. Just drawers, slightly smaller than a roller width sometimes,
jayemm
up high down low
Not the 40" your looking for but Grizzly has some chests. Can always put 2 side by side unless you're storing some long stuff.
Fedwrench
Valley of the sun
If Icon is more than you want to spend, I'm sure the Russeau made in Canada Tekton is also too expensive but, they're nice boxes.
I'd look for a used Craftsman 40 inch top chest and never open the lid :lol: Of course if you want to lock it, that would be an issue. :lol:
T
tarbellb
Oregon
The Tekton/Russeau are exactly what I want but i cant justify dumping that much into the storage
plus they weigh 200+lbs empty!
JradM
Alberta
Intermediate chests go between the top and bottom and hence neither have wheels nor flip tops.
However, you said up to 22" tall was ok. I'm not sure the dimensions of most intermediate chests will be large enough. E.g. that top one is 4" wide, but only 18" deep and like 10" tall. E.g. you could probably stack two of them, but that likely won't be as economical as buying just a top or bottom that's larger to start with.
The thing is, intermediate chests are meant as expansions to tool chests - so they tend to be only so tall or else the top of the tool chest becomes too tall to access.
A bottom chest without wheels seems like it's probably still too tall for your intended dimensions - but you could build a steel frame around one. Problem is, you'll want space under the top for clamps I presume.
All that makes me thing a top box without a lid is the most likely candidate. Anything you put there will be covered in dust, but maybe a bonus will be that it helps contain the spatter and debris?
T
tarbellb
Oregon
Thanks all I had no idea intermediate chest were a thing
I may have found a solution based on price and getting a little creative. Found a 72" Montezuma top box for CHEAP
It does have a (big) pop top but I will retro fit a sliding platform into it and remove the lid partially or fully to have access
🙏 I have the time and motivation to make that happen vs just pulling the lid off and making a dust and debris shield...
