Steve W.
I’m still in the “looking around” phase before I get to the actual “shopping” phase, but I have narrowed it down a bit.
Background: 24 x 30 footprint. One-and-a-half story with attic trusses giving a 10x30 room upstairs. Flooring installed to allow storage between the trusses. 2 x 4 studs in the walls, so only R-13 insulation. Full-length baffles between the trusses, then R-13. Also have R-13 in the bottom chord of the trusses. Upstairs area is also used as lounge area with futon and TV.
I have done some calculations and found I will need 15-18,000 BTU on each level. The layout upstairs will require a floor console air handler to fit under the window. My concern, and the reason for this post, is that all of the wall-mount units I have seen that I would use in the main shop downstairs discharge the cooled air from the bottom. Ceiling height is 8’, so air will be coming out below head height (I’m not short) and dumping right onto one of the workbenches. Are there any units that discharge from the top, which will run along the ceiling?
