torpedo heater experts please step inside...
dieselsmoke
North of Pittsburgh PA
This heater is several years old and started doing this. It produces heat and doesn't stink, but the popping is driving me nuts. When it's cold, sometimes the popping blows the flame out and the thing can't be trusted to start (it has a thermostat which is handy for unattended operation).
Took to the local repair center listed by Master, and while they worked on it and fiddled and cleaned it, I got it home and it's back to the same ****. They said they haven't seen one behave exactly like this.
The popping is so steady in time, that I wonder if it's electronic...like something wrong in the ignition circuit (like a bad capacitor). Does the spark plug run 100% of the time in these?
Is the nozzle dripping maybe? It's impossible to see the burn zone in these (without drilling a hole through it, LOL.)
Pressure has been varied all over the place. As you turn it down, it tends to get less "bangy" and when you crank it, it gets more violent.
crashcrater
Pinelands national reserve NJ
I have a Mi-T-M 75kbtu i got brand new a few years ago and it did that right out of the box.I emailed the company and they sent me a new housing that the nozzle screws into.They said it was not casted right.I think there was a air bleed in there that was cast over maybe yours is clogged. I read something about nozzles wearing also from fuel jetting through after lots and lots of use. AFter i changed the housing they sent me it was perfect
