Torque plus angle tool?
jeepnut24
Morrison CO
Ok, Im in the process of swapping in a Gen 3 GM small block. It uses a variety of torque plus angle fasteners. One of the books Im reading shows a nice SnapOn angle tool attached to a torque wrench. Anyone have a part number? Or other MFGs options for the same tool? I don't think I would like to trust my "Judgment" on an angle.
Thanks
Art From De Leon
De Leon, Texas
How well with that bad boy hold up to Powerstroke head bolts? Can it be used over 250 ft lbs when doing angles?
Powerstroke sequence...:wtf:
65ft
85ft
90*
90*
90*
Any idea to what each of those steps would work out in numeric ft. lbs.?
If the 1/2" doesn't work, SO also has a 3/4" drive torque angle gauge.
crewchief888
NW indiana
a lot more than you'd want to see printed in the specs.
it's not about the torque, it's about elongating /stretching the bolt to increase clamp loads.
out of curiosity we attempted to figure this out a couple times. we got vastly different final torque specs, found some large off highway headbolts were over 600 ft/lbs using the torque turn method.
i dunno but my back didnt complain as much about torqueing 26 head bolts to 240 ft/lbs + 90* as knowing i had to pull over 600 ft/lbs :lol2:
also ya get to buy more bolts that way, eventually the bolts stretch past their wear limits and need to be replaced.
:beer:
Toolhorder
Montana
65ft
85ft
90*
90*
90*
It's not really anything special, just an adapter with a gauge on it. The torque just moves through it it's not stored in it or anything. It shouldn't break. I've done sequences like the one above without a problem.
The newer electronic torque wrench is way better and faster in my opinion but I haven't needed one enough to justify the cash.
Art From De Leon
De Leon, Texas
I used mine mostly on JD 446 rod bolts, the initial torque is 55 ft lbs, followed by X degrees. The only head bolts that I remember that required torque turn were on the 619
engines, but the last dealer I was at never had a tractor that big in the shop with engine, or power train problems, thank GOD. I don't even think we had the splitting stands, and special tools to work on them.
seth_man
Rhode Island
65ft
85ft
90*
90*
90*
ive used my 1/2 tech angle for powerstrokes before, it will hold up. but its much easier to use a big breaker bar and an angle gauge.
crewchief888
NW indiana
i used to build a lot of deere 6619. those 26 head bolts would wear your *** out. i gave up using the angle guage, and started marking a deep socket at the correct degrees. a long SO 3/4dr handle/breaker bar head worked best.
the last dealer i worked at i was in the rebuild room for almost 8 years.
we averaged 1 engine / week
1 trans / week.
300 water pumps / year
2-3 radial piston pumps/ week
1-2 steering valves/week
plus pumps, excavator cylinders, accumulators, basically anything that could be removed from a machine.
:beer:
