Definitely check out the wrench, and atleast check it against your ½". AWD can be wildly hit or miss. Maybe someone bought it to use once and then returned it.So the culmination thus far -
Amazon warehouse deals came through with the breaker bar and torque wrench combo for 350! They also had some AWD tekton 3/4 metric sockets, and I got a 4" extension.
So I assume the new extension and the warehouse deals sockets will be fine. If the wrench is damaged in a way not deemed usable, I'll be hunting for that again.
Thanks all for your input.
Not true. Let's say you're getting 103 ft-lbs at a setting of 100. Put that thru a 5:1 multiplier and you'll have 515 ft-lbs when the target was 500. But the error is still the same 3%.Yes. If the wrench is off 3% and it's a 5:1 multiplier, then you will be off 15%.
Yes, my bad!Not true. Let's say you're getting 103 ft-lbs at a setting of 100. Put that thru a 5:1 multiplier and you'll have 515 ft-lbs when the target was 500. But the error is still the same 3%.
Fwiw, high torque specs usually have a tolerance or range rather than an exact number.
Not sure how that would be amazing. It's a pretty obvious concept to me. Ft-lbs is literally a measure of effort.Having used digital torque wrenches which record data, one would be amazed at how much user input effects the torque applied.
Yeah it's difficult but I don't find it amazing.Until you realize how hard it is to reach a given effort in a repeatable manner.
