expatriated
Continuing my rather limited education in mechanics.....Can someone elaborate for me what adjustment (if any) is needed when you use a torque wrench with an extension? I've read various opinions on this and I don't understand it.
For example, if I use a 10 inch extension with a socket on a torque wrench, why should an adjustment need to be made? Isn't the the ratchet mechanism turning the same distance as the socket on the other end of the extension? Or is it gathering more resistance? If it calls for 20 ft lbs, should the wrench be set at 20 ft lbs or some other amount based on the fact that a 10 in extension is factored in?
Does it make a difference if a crowsfoot is used?
Thank you!
Thank you!
It depends on the country of origin of the torque wrench.
