Torx Plus Tamper aka 5 point torx
Jure
Croatia
have you eve needed one and where? also where 5 point torx bolts are common beside air flow sensor on vw's? :dunno:
Oahu, Hawaii
Never had the need to use them, nor have I seen one in the wild, but I do not turn a wrench for a living, just fix or upgrade some things that I can do myself on one euro and one Japanese car.
I would buy a set of sockets/bits to do a job if I came across it, but not otherwise.
bob15
Northeasten, CT
Diesel injection pumps. Look just below the brass thermistor (Stanadyne DE10 pump).
4xdog
Santa Fe, NM
There's a BMW motorcycle secure oil filler cap accessory that uses a five-lobed security Torx.
shanny19
PNW
Pivot on some Leatherman tools. Bought a whole set, only needed the one size.
cj7365
New Mexico
They are on a 96 dodge Dakota ignition cylinder (starter switch)
MrSmiley
Roll bar on a YJ, and probably TJs. Haven't looked though. Also on Xbox 360s IIRC
DanInVA
Seen a 5 lobe torx on a Mercedes inside the side view mirror assembly
DC73
Lubbock TX
The first picture is tamper proof Torx aka security Torx, the second picture is tamper proof Torx Plus aka Security Torx Plus.
Thanks for clarifying this. I've never come across the Torx Plus but I had heard there was a different style. On the regular security Torx, I just use a punch or a small chisel and break off the pin so I can use a regular Torx driver.
DC
Mohawk Dave
SoCal
I want to know who the hell is trying to detach and steal bathroom partitions anyway. Yea, I know they are just normal tamper torx....but how many gangsters would be unscrewing them if they were phillips? Those dudes are so pissed off they get on their knees in a filthy bathroom, over a filthier toilet and carve their gang name in the ******* circle.
xbeatles4x
Cutler Bay, FL
My Volvo S60 has the Security Torx Plus (5 star torx security) screws to hold the MAF to the housing. I had to use a screwdriver to remove it and replace the screws with normal torx screws. Only time I have ever come across that particular screw head.
zcbauer89
NW OH
You're going to see them a lot on John Deere injection pumps, Standyne injection pumps, and some Bosch injection pumps.
SantaAna12
I get the prison application, the injection pump, but why use these on a regular shifter (etc.) app?
