torx set
Tallpilot
Orlando
Neiko are fine. The Capri advanced series are probably a little better for similar cost.
https://capritools.com/shop/master-star-bit-socket-set-60-piece/
They don't seem to have a long master set. So Neiko may still be the value leader there.
VIM is tool truck level awesome. But more expensive.
https://cloud1.shopsite.com/donofish/product402.html
This is stupid cheap though if you want to see what the fuss is all about (1/4" drive also helps with access in some cases):
https://cloud1.shopsite.com/donofish/s7aipxl-details.html
wkndwarrior29
NorthEast
It depends on what you are working on. On my bmw's, low profile is important. I'd recommend some dual drive sockets first. https://www.homedepot.com/p/Mayhew-11-Pc-Torx-Dual-Drive-Set-16003/313309833
If you strip one, you'll want some VIM half cut sockets on hand.
Then I'd prioritize a good bit set, I prefer VIM.
Last, long screwdriver bits.
Those large kits never have the best selection for the money.
Sent from my Pixel 3a XL using Tapatalk
Jaysreal
Pittsburgh, PA, USA
I always thought it was funny that companies call them "master" sets but don't include stubby, regular and long. But for cost and quality I like VIM. Another brand that I've seen many rave about is Capri.
Sent from my ASUS_I01WDX using Tapatalk
Wamsutta
Amarillo, Texas
I have a 7-piece Snap-on set. I don't even think VIM or Capri was around when got them. I probably got them sometime around 1995 when I was a Piper Aircraft Master Wax & Buff Tech. :D
https://shop.snapon.com/product/TORX-Standard%2C-Chrome-(3%2F8")/7-pc-3-8"-Drive-TORX-Bit-Standard-Socket-Set/207EFTXY
Tallpilot
Orlando
Those are cool. I haven't seen those before. Mayhew seems to understand how to make high quality stuff in the U.S. but not charge astronomical prices for it.
No joke. 3 or 4 'master sets' and you finally have everything you might need. WTF?
Jacobson
In that Neiko set, look at the close up zoom.
What's the difference between TP30, T30, and TT30?
That kits seems very redundant. I never heard of anything beyond T30.
Mr_B
Reading
lot of sets go up to T70
T47 a size that materialized on german junk .
Tallpilot
Orlando
As already mentioned, that would be Torx 30, Tamper Proof Torx 30, and Torx Plus 30. If only this 'master set' were redundant. Sadly it is missing tons of ****.
Here's a T100 so 30 isn't even close to the end of this mess.
https://www.tooltopia.com/vim-imptx8100.aspx
Also the Neiko set doesn't have Tamper Proof Torx Plus AKA IPR:
https://www.amazon.com/dp/B004CGKQNO/?tag=atomicindus08-20
Oh and external Torx plus:
https://www.amazon.com/dp/B00JF5FA42/?tag=atomicindus08-20
Those OTC sets above seem to be missing quite a few sizes though. /sigh
Jeez, all of a sudden that VIM 'master set' looks a little cheaper. Good thing the OP didn't ask about XZN or Ribe. Makes that 6pt vs 12pt hex debate seem quaint doesn't it? Don't forget about 12pt external AKA double hex. :beer:
https://www.amazon.com/dp/B000I1LTVU/?tag=atomicindus08-20
Jaysreal
Pittsburgh, PA, USA
Okay, Torx officially makes no sense
Torx = 6 star
Tamper Torx = 6 star with hole
Torx plus = squared off 6 star
Tamper Torx plus = 5 STAR WITH HOLE?
Who comes up with this stuff? I've always called tamper proof Torx plus; pentalobe.
kelpaso1
MEMBER EMERITUS
New Brunswick
What is with all the "tamper proof" bits for sale? I have never needed one unless for some cars interiors. Seems like a hole drilled in the center would make them weaker.
American Locomotive
Rhode Island
There are plenty of things in cars (and other equipment) that use tamper proof bits. Since the hole is at the center, very little strength is lost by it being drilled out. It's the same reason why a car driveshaft doesn't break despite them only being a bit thicker than exhaust tubing.
Fedwrench
Valley of the sun
I've used them on ABS modules, and a few other places. The hole in the bit is filled by the pin in the center of the Tamperproof screw.
Tallpilot
Orlando
Torx = 6 star
Isn't this fun? Tamper Proof Torx and Pentalobe seem very similar but Pentalobe doesn't require the hole. Torx is just about as 'universal' as USB.
https://www.wihatools.com/precision-five-point-pentalobe-screwdrivers
Once we get into small Pentalobe (Apple stuff) then we also have to talk about Tri-point.
https://www.wihatools.com/picofinish-tri-point-000-screwdriver
Oh, we totally forgot about Mortorq if we are still talking about vehicles:
https://www.amazon.com/dp/B01AKFTXMK/?tag=atomicindus08-20
See, this nonsense is a real issue. Of course there are hacks to get around it but this fastener diaspora is utterly insane.
