ZSK
I need some advice on how to shorten a trailer jack, if it is possible. I recently rebuilt the tongue of a neighbor's trailer. Part of the process was mounting a new weld on Reese Trailer Jack.
I used this model:
https://www.reesetowpower.com/products/trailer-jacks/square-jacks/square-trailer-trailer-jack-8-000-lbs/USX3uVM!Va6aHkvKOsw4wiBozH5Qt|fiWmTP0QzZD0Y=
Before mounting, I checked to make sure I had enough lift height but didn't think to make sure I had enough ground clearance. I set it up by measuring with my truck, but the normal tow vehicle sits lower. Lower enough that the foot of the jack will drag on the ground once in a while.
I was able to remove the drop foot and trim some of the inner tube off but when hooked to the tow vehicle there isn't enough room to remove the foot.
I believe that I can just cut the length of the outer and inner square tubes and then re-drill the pin hole higher for the foot, but I wanted to see if someone has already done this or has a complete exploded view of the jack.
I used this model:
If I can shorten the jack by three or four inches, I think I can accomplish that in less time and leave an overall more compact package. If I can't shorten the jack safely and retain proper function, then the option will be to cut it off and position it higher.
