Once I took everything off of the backing plate, I had to decide if I was going to rebuild or replace the brake parts. The first order of business was the wheel cylinder. It looked like it could be rebuilt but I found a new one for $22 so replace it is. However, I still needed to get the short little link rods out of the pistons. The first on freed up with some heat and prying. The second one, however, was explosively ejected to the darkest corner of the shop and could not be located.
So, off to the lathe to make another one. I found some brass stock that was close enough in size.
First, I turned the small end:
Then faced the other end and turned the taper:
A short trip to the band saw:
Some file work and done!
I've got a bunch of parts on order including a new parking brake cable since the casing of the old one was eaten in two by the fan on the generator.
