I need help identifying a transmission jack I bought a few months ago, it seems like a pretty heavy duty and unique in its build configuration but I cannot see having been searching for sometime any jacks used or currently for sale that are like it to get a drawing or seal kit for it.
Its leaking out of the foot pressure release valve, so I am trying to source some seals for it.
I have tried to use o'rings in the foot release valve but the recess in the piston takes 1 1/2 times the diameter of an oring of this size diameter to fill the recess and with one o'ring it leaks and you cannot get 2 o'ring in the groove without damaging them.
Unfortunately, when I had the valve out I did not measure its dimensions so I'm going to remove it again shortly for measurement.
It does not have any manufacturer markings
Any advise as to how to repair it I would be grateful for or
Is there a company that you can measure the dimensions/recess and source the seals from.
