Why do I need an engineer? I thought rafters were the way to go for years? As long as I put in a rafter why would I need an engineer?
It's traditional in this forum to treat people with disdain who ask framing questions. I don't know why that is, but I can say that this exact question has been asked here in this forum many hundreds of times, and that makes a difference in the answers of course. A question you might ask yourself is what do you personally understand about forces? Do you understand where the weight is going?
In a 26 foot wide building, modest size rafters are graciously adequate. It should be obvious to anybody with an ounce of sense that the weight of the roof would like to push the rafters down, and the best way for the rafters to fall is to push the walls apart, or break loose from the roof and slide. So the rafters would like to push the walls apart. There are two ways to deal with this; you can either tie the walls together or you can hold the center of the roof up. The former is much easier, by a mile. The latter takes a lot of stress off the rest of the roof.
Since you want to raise the effective ceiling height, by definition you don't want to do the former.
So this raises a question that is something like this:
If I tie the rafters together above wall height, increasing the bending forces on the rafters, then how big would the rafters need to be? That's an engineering question.
Or, if you want to hold up the peak of the building, you need structure spanning the entire buliding holding up half the weight of the entire roof. No joke.
