trusses
g5champ
Hi all, I need some info. I'm about to begin building a 28'x28' garage and i want as much usable space above as possible. I'm torn between a gambrel style roof and "room built-in" trusses. What's the most floor space available from a 28' truss?
LB-1911
Northwestern Il.
"We" could use some information as well.
Do you have a maximum height restriction?
Do you have a restriction as to roof pitch?
One example of a 28' storage truss w/a 12/12 pitch is
kd3pc
Northern Neck
Remember, that if YOU are building this, a 12 and 12 pitch roof is a bear to shingle/roof, plus setting those trusses will all but require a crane.
best of luck
G
g5champ
Yeah I guess there are no real restrictions...I will be doing a majority of the roofing so maybe 6/12 - 9/12 on the pitch and again no height restrictions per se, but I'm trying to avoid building an actual second story.
Maximum storage would be a gambrel roof. However, depending on the loading for the floor, you may have to go with wooden I-joist or parallel cord trusses for joist.
My buddy store hay "upstairs" in his barn. A whole lot of parallel cord trusses 16" O.C. Fresh cut hay (not 100% dry) is no problem !
1953mercury
Steamboat Springs CO
12/12 pitch can be a positive if you live in snow country, and besides the extra floor space I like the look of a steep roof. They can be a pain to cover, but you generally only do it every 25-30 yrs. If you have the right equipment it really isn't bad. Metal roofing (which is all I use up here) goes up very quickly. Mike
bczygan
DETROIT! Arsenal of Scrappers
The MOST space available is a mansard roof/wall with a flat roof truss, creating an entire second floor.
Or just build a two story garage with a flat roof.
Or:
