BurtEggley
- Joined
- Oct 8, 2024
- Messages
- 913
Background: have a Husqvarna front tine tiller I bought used over the winter. They were leaving the state and the guy I bought it from said it only had a couple hours on it in their rocky soil up the hill, but the tines are not really that worn so i don't think it has seen a lot of use. Looks pretty new, circa 2020-2021 but probably It replaces a 30 year old Craftsman that I sold a couple years ago, same basic design, probably MTD. Many of the parts are the same, although not as sturdy as the ones made 30 years ago. Never thought I would use one again when I sold the Craftsman but the garden was getting too compacted so I shopped for a used one. The garden is too small, about 200 sq ft, for a rear tine unit. Anyway the design, tines, transmission etc are the same other than the frame is slightly different, and engine is a Kohler instead of a Tecumseh. Works well although reverse is really fast and takes some getting used to because as it come back, as one backs up the reverse lever is hard to let go of. Would be easy to trip, fail to let go, and have it go over a person. The Sears had a knob one pulled which worked better. Sears was a 26", this is 24". Anyway, back to the question. Many of the bolts on this thing are loose, and they don't feel like grade 5, although they are supposed to be grade 5 according to the parts description. Feel, look and wear more like grade 3. The bolt heads don't have the three slashes either. While using it yesterday I noticed the engine seemed to be torqueing to one side and sure enough two of the engine mounting bolts had vibrated loose. The remaining two were also loose. So I used what I had on hand, fixed it, and it is Ok for now but I really need to replace the fasteners that are loosening. So any thoughts whether yellow zinc grade 8 would be overkill or anyone have opinions if standard zinc grade 5 would be adequate. Stainless would be too soft, and the unit gets stored in a dry shed when not in use.
