Trying to find examples for this build...
JMPeters
Seattle,WA
I'm looking for other garages that people have built or seen that are 2 stories and have a car lift in the bottom story.
I'm trying to build a 24 x 32 garage with a second story and a height that is enough for a car lift
The max height i can build in my area is 25'
The max lot blueprint is 800 sq ft
The reason I'm looking here is because I can't seem to find any plans online.
Thanks.:rocker:
txvwnut
Bedford, Texas
Mine is 20x26 and 20 at the peak with 14' side wall height. I have a mid-rise lift and set the upper level floor at just over 10' high and still have plenty of headroom upstairs. If you are wanting to use a full rise lift I would go with a 25' peak with maybe a 16' side wall height and run the upstairs floor at 12 or 13 feet high.
pauls340
North of Motown
Our City in Michigan would only allow detached garages to be 14' max and I knew I wanted to put a lift in it. I also knew I wanted overhead storage and a place to hide the furnace. I got creative with my 24x26 garage and used Storage Trusses on the left side and Vaulted Trusses on the right side which allows a height clearance under a lift to be a full 74". Also, the best, best, best possible decision I made was to use Vapor Lock Enhanced Concrete for the slab on ground floor. There is zero moisture emitted from the concrete. VLEC is a concrete admixture that waterproofs and vapor proofs concrete. The best $300 I spent. Good luck
sublimate
Colorado
I had similar constraints, so did a 2nd story over half my garage and left the other half open for height for lifts.
txvwnut
Bedford, Texas
All of my build pics were lost when I lost a harddrive(thanks modern technology). But I will try to get some shots of the inside this afternoon.
motofool33
Currently North of Houston
do you have to make it out of wood? or can it be a steel building?
cause with the steel building you wont loose much height due to the roof.
You can do a Mezzanine rather then a full 2nd floor. search garage mezzanine in google lots of things come up for ya.
my shop has 19ft to the eves plenty of room for two stories, i want to put in a mezzanine with an office space some day
