Trying to ID a Williams socket set
bigmike6970
Hello, I found this set at a thrift store and I think that it is a Williams set. However I have looked at this alloy-artifacts site and did not come across any with the markings that are on the the set I have. Maybe it is too common of a set for them to put up.
Just want to see if I can confirm is these are Williams and possibly from what time period.
they are marked with the w inside the diamond and all of the tools are just Marked with an S and no other model numbers on them.
ganymede
New England
It is definitely Williams.
Don't know the time frame or why they weren't marked with the company name.
I think they were either an economy line or made for govt.
bigmike6970
ganymede,
Thanks for the quick reply.
It would be neat if they were made for the government, even just to imagine what they may have been used to work on.
I hope I can find more information on them.
Bigmike
bigmike6970
Thank you 3baygarage and jeremy v
jeremy, Looking I have been reading through that link you provided. I did not see that section when I first looked at the Alloy-Artifacts site.
the sockets that are with the set I have are of the form of the sockets the site indicates are from 1935-1939 with the single deep band, smooth upper and a rough texture from the line down (see pictures) but again with out all of the standard markings on them.
I have also included a picture of the carry box they came in
I gave $35 for the tools, I was trying to get the guy lower. I don't think that I got the deal of the century on them of course but I like the look and feel of them, and now the mystery of why they do not have all the markings makes them more interesting.
BigMike
bigmike6970
Jeremy you posted,
"If you look at the square drive end of that ratchet you will notice the ratchet cover plate is round, screwed on, and it requires a tool like a pin wrench to turn it. That's classic old Williams."
I checked and it is does have the round cover plate with the 2 places for like a pin wrench/spanner to take it off, I wondered out they got it together since it did not have any screws on it. makes sense now, thanks again.
Mike, they also created a name called Volume. It is the same 1/2" ratchet as yours. I think I have a few sockets floating around.
Oddly, I don't believe these were cranked out in great volume because they aren't seen all that much.
Alloy artifacts has an example of a 3/8 volume.
bigmike6970
Thanks again 3baygarage and ganymede for the additional information.
Looks beefy on the inside. Seems like I picked up an interesting set. It all seems to work fine. I am sure at some point I am going to use them to work on something.
Mike.
