Hi. Two months ago you all helped me figure out the panel popping noise on my new Wayne Dalton 16ft garage door:
www.garagejournal.com
which was resolved by them sending out two different techs who straightened (somewhat) several hinges, and the popping noise is now pretty much gone. But now the dang thing is squeaking a lot, so I'm trying to figure out what is wrong. Here's a video I just made, the squeaking gets noticeable especially near the end.
I've got the upgraded nylon rollers on the door and had just lubed everywhere the tech said to using lithium grease, which quiets some of the clatter but makes no difference at all for the squeak. Its hard to pinpoint exactly where the squeak is coming from but as best I can tell its loudest when I stand on a ladder and get close to the center of the door and put my head near the torsion spring (its a torquemaster), which I'm told is not lube-able since its enclosed.
Am interested if you all think the squeak is likely to be the spring or something else. I called a local guy just to get a price and he said he could replace the spring with the more traditional larger type spring which is exposed and lube-able, for $675. That's more than I want to spend but if I'm gonna be stuck with this squeak for ten years I might actually go down this route and get more quotes. Any input appreciated. Thanks.
looking for feedback on garage door noise
Hi. Just moved into a newly built house and had a local chamberlain installer put in a B2405 opener. He also lubed some of the parts. He mentioned that the door itself will hopefully quiet down over time. That was two weeks ago - the motor is quiet but I'm *really* noticing the noise the...
