Hey guys, what does the term speeder ratchet mean??? Is that the offical name given to this tool?? Thanks
Speeder means the handle (or some portion of it) floats free from the articulated wrench itself allowing you to hold the end of the handle with one hand firmly (and turn quickly while being stationary in one hand) and the articulated part of the wrench/driver (and thus socket or bit attacted to it) to be held and guided with your other hand and held loosely thus allowing you to run up or remove loosened fasteners very quickly and accurately by hand once broken free.
Used for decades in auto shops and on race teams before the proliferation of battery and air impact tools to speed the task.
Good part about speeders is that overtorqing or damaging a fastener is seldom and issue once it is loose or run up.
The Snap-On 9/32 drive speeder "t" wrenches from the turn of the century up to the 60's used a free flaoating knurled collar on the drive shaft and the "t' handle was fixed , which reversed the position, but with teh same results.
Where the Op speeder ratchet shines is that you have both in one. YOu can break a fastener free, than remove fastener quickly with the same ratchet.
Same with installation.
Used to use a company provided one quite almost daily while in light mfg.
