Between 265 & 485 SQ/FT Tuff Shed Garage Build
longlv85
Garage is nearing competition and wanted to share. I remember lurker on this forum a long time ago hoping one day I can share a cool garage of my own. So here we are.
Started in October 2022. Laid out a 16x30 area to give me an idea of the space.
Has area dug up for a monolith foundation as required by the town.
Few days later we had concrete forms installed and concrete poured. The excavators messed up and dug the center part to deep and the footing to wide. So I ended up with walls that were 24" wide and 12" deep. The middle slab was between 6-8" thick.
Tuffshed came out and installed garage in a day. There was some hiccups with anchors but that was resolved as well
Up next my father inlaw came out to hook up the 100A service and tuffshed came to install the Insulated Door.
Next up with install a people door in the rear
next I installed some plastic gutters
Then installed the garage Vac. We ended up running a new dedicated circuit for it
Quick trip to Napa to get some custom Hoses made for the Maxjax and Wall Mount the Power Unit
L
longlv85
Next up was insulation and sheet rock. R13 Walls and R30 Ceilings.
After the painful Insulation and sheetrock. We painted the garage. Went with Dead Flat Black ceiling and grey walls.1683688989452.pngUp next was the floor.I went Nitro Flex Diamond tiles
Next up was Heating\Cooling. Went with MrCool 18k BTU Advantage system.
L
longlv85
Next was stand putting together the cabinets. Yea I know the ceiling is a mess. Not sure why. Same Paint bought and mixed at same time. lol
Didnt have a good place to store the Lift Adapters so bought some peg boards and 3d model and printed some. Also Mounted the Ergo RS Creeper.
Picked up a Rockler Hose reel and accessory rack for the vac
mounted a Black Dry erase board
L
longlv85
bring on the lighting. Installed 2 Set of Honey Comb Lights. Both wired to different 3 way switches.
Next up is the driveway. had the old one ripped up. They will be paving all around the garage.
xtremek
St. Johns, Mi
You're braver than I am. I'd be afraid the dark walls and ceiling would soak up too much light. I have over 35 lights in our shop, with wood on 1 1/2 walls, white on the top 2/3s of the rest, tin ceiling, and I still wish I had more light.
L
longlv85
I worked with a supplier in China to come up with a configuration to fit my garage. Cost of Product plus express shipping was surprisingly cheap vs buying the same lights on amazon.
L
longlv85
Paving company came out and knocked it out. They wheel barrel asphalt around the ground then compacted it down. Then use big machine for the rest. They had left over asphalt so the built me a curb for the grass and filled in my neighbors driveway to help patch up some of their large mud pits.
TR - Front Right-TR - Front Right 5-11-2023, 1-16-41 PM.jpgTR - Front Right-TR - Front Right 5-11-2023, 1-21-01 PM.jpgTR - Front Right-TR - Front Right 5-11-2023, 2-23-22 PM.jpg
L
longlv85
Great looking space! What are you looking to do (in terms of work) in it? I like the s2000 too!
Just maintenance on our cars and help out friends and family. I mainly wanted the space for a workshop for my 3D Printers, CNC Routers, and Laser machines. My wife is kicking my workshop out of basement. So far we Installed lift kit on ram 1500, full suspension on civic, 5 gallons worth of oil changes. Future plan is to turbo charge the s2000 so will need to drop the trans to upgrade the clutch so maxjax will be great.
Dissent
After getting some bonkers quotes back for Red Iron buildings, I'm looking at doing exactly what you did with a 20x30 Tuff Shed but I need 12 foot ceilings for my LandCruiser and a lift. Would you mind sharing what this project ended up costing for the building and what did your slab run you? Thank you.
L
longlv85
Sorry for the Late Reply.
Building $13,626.90. This included Tuffshed pulling all the required Permits.
Monolithic Foundation $7,800
jonshonda
Wisconsin
Very cool build, and a perfect setup for working on pretty much anything a fella would need. I'm jealous of the lift, but know that at 6'2" I would likely need 14' ceilings to pull off a lift in the garage.....hmmm.
I've always lusted after the S2K but the prices for nice used examples is a bit (ok a lot) outside of my budget. Then there is the whole "I'm 6'2" trying to squeeze into an S2K issue". I'm thinking of doing what you did and finding an S2K in need of some love, playing with it a bit to see if I can make myself fit and still feel comfortable driving it.
L
longlv85
Looking back, What I wish I would've done was push for higher ceilings but even with the 8' walls I can lift my truck up and still able to slide under it to do oil changes with the oil catch can.
Skellyii
KC Area
Uh...
Is that a Mazda Miata in your profile?? And you're 6'2"?
How do you squeeze in to that? I'm 6' and I barely fit. My son is a little taller, and he'll only drive it when we have the top off.
Don't get me started on the S2K's...I want one as well.
jonshonda
Wisconsin
Uh...
Ultrashield racing seat bolted directly to the floor pan.
