Two Post Lift Wiring Problem
Gunnert
My detached garage has an older Miller Two Post, 5000 lb rated, car lift. I shorted out the momentary contact switch that operates the motor. I replaced the switch with a two post, automotive starter switch which immediately shorted, caught fire, and tripped the breaker. The motor is wired for 220. The switch has two wires. Where can I find a switch that will work?
nehog
Jaffrey, NH
Since you have no idea what you are doing, I'd suggest you contact a lift installer/repair person to fix it for you. Putting in a switch rated for 12 volts in a circuit that is 240 volts has to be about as bad as it gets.
dave*99
Coastal NJ
G
Gunnert
PatternP, thanks for the help. I've ordered the recessed switch.
G
Gunnert
Got the switch and installed yesterday. Had to add a deeper box to accomadate the depth of the switch. Thanks again to Patten for the help.
G
Gunnert
This is what you need...... Just make sure the voltage and amp capacity are correct.
http://www.automationdirect.com/adc...ushroom_Pushbuttons_(Non-Illuminated)/HT8AERA
A few months back I took your recommendation, ordered and installed the switch. But, it periodically sticks and I have to run to the panel to trip the breaker. When I open up the box the switch is stuck open, I use a scribe to push it back to the closed position. I've tried dialectic grease to lube but seems like the contacts are sticking for soom reason or the return spring isn't strong enough to close switch...
Any ideas...?
pattenp
Virginia - USA
Any ideas...?
Sorry but I don't. You'd think the the dielectric grease would do the trick. Apparently the quality of the switch isn't so great. Did the switch have any warranty? Which switch mod# did you actually get?
Here's another switch replacement option...
http://www.automotiveshopequipment....wer Unit Parts/Power Unit Parts.htm#SPX Parts
or
http://www.automotiveshopequipment.net/pages/Lift Parts/default.htm#Power Units
G
Gunnert
Thanks for the links. I took the switch out and work the diaelectric grease into it. I'm going to give it one more shot before I replace it.
The switch I have is not a cheap one, cost about $40.00, don't know if company would replace or not....
nehog
Jaffrey, NH
Wrong switch (easy mistake to make) the one you have is a low voltage, low current logic level switch with gold (low resistance) contacts. (the E in the HT8AE is the specification...)
Eaton makes good products, but you need the right switch.
pattenp
Virginia - USA
That's not the switch he should have bought. It was just the switch that was shown as an example on the web page that I pointed him to.
Edit: I think you have your code letters out of place the HT8E is the logic level switch with gold (low resistance) contacts, not the HT8A.
pattenp
Virginia - USA
My bust, which switch should I order?
Thanks
I,m not totally sure you bought the wrong volt/amp size switch. Do you have the number from the one that you did buy? I know the last switches I posted the link to from the lift parts supplier are correct. but I don't know if they fit your lift switch box. The Eaton HT8A series at 240V is rated at 30A interrupting, 10A Thermal Current, and 3A load break. So that switch may be a little weak for the motor load. What is the amp draw of the lift power unit motor?
G
Gunnert
I have no idea what the amp draw is, the lift is an old Miller, two-post, chain...
But I did order the HT8A.
justsam
Penngrove, California
Look at the motor nameplate or data plate for information on voltage, current, HP, duty cycle, etc.
Is there only the switch in the circuit, or is there some type of contactor/relay that isin the circuit?
How are you wiring the switch in the circuit?
How did the the old switch fail is it now permanently closed, or never makes contact?
G
Gunnert
Plate reads 240v 17 amps. Old switch was 2 post NO, momentary contact. I fried the old switch by arcing it... I was told by supplier the HT8A was rated 30 amps/240v....
