Type of wood?
Bamacruiser98
img_8138-jpeg.2204106
I’m refinishing this little side table, what type of wood does this look like?
RoninB4
Under My House
Furniture makers sometimes used less expensive wood that was local. Pecan comes to mind but it's one of the softer hardwoods. Have you tried using your thumbnail to determine hardness? Would like to see this during/after finishing.
jar944
Northern VA
Pecan is incredible hard for a domestic hardwood at 1800+ Janka. It's also ring porous, which the picture doesn't show.
Bamacruiser98
Doesn't look anything like walnut...
@Bamacruiser98 what have you done to strip the parts you show?
Do you have a view of the top?
Here’s the top and another pic of side. I’ve had sanded everything except for the two sides which I used my sander but will be hand sanding everything before stain. Started with 60, 220, 400 and I’m currently about to hit everything with 1500. I usually do a light 3000 swipe over everything as well but not sure I’ll do it this time. The top looks like a cheap veneer that I’ve done several times. Probably a few different type of woods. If I had to gauge hardness I would say it’s a 6 or 7. Pine being 1 and maple being 10.
Bamacruiser98
My thoughts were also black walnut.
Any place you can shoot an image of the end grain?
And BTW those metal skid inserts on the bottom of the feet will do quite a number on wood floors; they should be removed. You can use dense felt instead.
I usually remove or just use pads if I keep the piece.
Bamacruiser98
Looks like some form of "mahogany" to me.
400 and up? You're nuts!
That was my guess too but didn’t want to lead anyone. Not the biggest fan of hog but it’s really pretty piece so I’ll probably keep it light colored as I can. Thx for response
johnre
Portland, OR
manwithtools
Lebanon, TN
Also, a lot of furniture will use many different species of wood. The staining, tinting and finishing steps would make it all look the same.
BurtEggley
As others said, it reminds me of Philippine mahogany. We had one piece of furniture my dad made of it when I was a kid.
lilredex
Toronto
Take a look at this site, may be some ideas there you can use.
Bamacruiser98
I finished the table last week. Very happy with it and I’ll gladly keep it if it doesn’t sell. I cut part of the leg out to get rid of that design, a lot of sanding, stain and sprayed it with satin poly.
