Ok so I am going to be using cedar rough side out. My concern is that water may get between the seams of the siding when it is **** jointed in the field and also where it is fitted against the corner boards. With the siding I have removed there was some moisture or water that seeped by on the corner boards that left water stains.
My big concern is that since the zip board is OSB but coated will it stand the test of time. after reading replies I don't think it will benefit me to wrap Tyvek around the entire house if I use the zip board. Was considering just buying a couple of rolls of 3' wide Tyvek and running it up all the inside and outside corners. This way any water that does get between the siding and corner board I will have the Tyvek as an extra barrier so the water can just run all the way down past the sill
